VX2100 is here! But...
I just got my VX2100 from B&H (DV Info sponsor) and I got the MACK warranty, camera bag, long life battery, wide angle lens package.
First of all, this camera is beautiful! I pointed it under my desk at work and it was like I had a flashlight on! Now here is the But... The shipping box it came in had air-bubble packs around three sides of the actual camera box (because we all know that the bottom layer of the cardboard shipping box never gets jolted). Ha, ha. And, on the top of my VX2100 box, there was a great big boot print. Nothing like using your boot to move a $3000 piece of precision electronics around on the floor, either that or using the box as a stepping stool. I was able to simply dust it off, so at the very least B&H packaging department could have done so before sending it. I took a picture before I dusted it off and wlll post when I get some time. I only mention it because I know B&H monitors these threads. I have a warranty so if anything is funny with the performance of the camera, I'm not worried, I'm only out the time to wait for it to get fixed. :-( Grant |
This is a new cam? You better double-check your warranty right now and read the fine print on parts and labor.
"Shoot first and ask questions later" |
#3 | |
The camera does appear to be new, it's just the boot print on the box (the one the camera is in when it comes from Sony) that had me worried, like if a microchip inside the camera could possibly get knocked loose from a "kick across the room". I'll also contact B&H directly. Grant |
#4 | |
If the box is not crushed, nobody stood on it and the box is designed to protect the camera in quite a big impact. Maybe someone has a big boot-shapped rubber stamp and they randomly use it to cause consternation? :-) The only thing I'd be worried about is back-focus if the camera really took a hard lick. Auto focus will mask a back-focus issue so you want to put the camera in manual mode, zoom all the way in on a subject that has big, high-contrast bits (like a checkerboard pattern printed with a laser printer). Manually focus on the pattern and then slowly zoom out, watching the video image on a large monitor/TV. The image should stay in focus all the way out. If it does not, then the back-focus needs adjustment and that must be done at a service center. But that would be under warranty.
Mike Rehmus Hey, I can see the carrot at the end of the tunnel! |
#5 |
Grant, I hope you'll let us know how you like the camera. I'm considering buying one from B&H myself.
#6 | |
Grant |
#7 | |
Good luck with the follow-up at B&H. |
#8 | |
Grant |
#9 |
Did you use the Impact DVP-WA50-58 wide angle lens? If so, is it true that this lense is a zoom through?
