Aspect to After Effects at DVinfo.net
CineForm Software Showcase
Old August 24th, 2007, 12:49 AM   #1
Hi!
My cam: Canon HV20, 24p mode
I ripped my cassettes with AspectHD into 24fps (pulldown, progressive) but can't work with them in AfterEffects...on one file i get a strange error message, the other video can be viewed on the preview screen, but then i get strange lines all over.
To top it off, when starting AE i get a nvidia message.
just check it out on this screenshot i took :)
For your information and to clear things up: the video which gets those weird lines on the preview screen isn't getting any error-message, but the other one.
PS: Some german guys at slashcam.de suggest that i shouldn't work withaspect hd, but use premiere and do the pulldown afterwards...hm,...whats better
Is aspect hd's pulldown to 24fps conversion interfering with AE?
[img=http://aycu28.webshots.com/image/25347/2003766008133082933_th.jpg]
Chris Cosic is offline   Reply With Quote
Old August 24th, 2007, 05:09 AM   #2
Other folks are having the same issue... see this post
http://dvinfo.net/conf/showthread.php?t=98146
as to the Nvidia msg.... do you have the latest driver set?
Old August 24th, 2007, 08:56 AM   #3
CTO, CineForm Inc.
Removing pulldown before compression an storage is best. The AE CS3 fix, with any luck will be out later today.
Old August 24th, 2007, 12:53 PM   #4
Will the AE CS3 fix mean I'll be able to restore the default AE importers and undo the CTRL+SHIFT thing?
-Steve
Steven White is offline   Reply With Quote
Old August 24th, 2007, 01:39 PM   #5
CTO, CineForm Inc.
Yes, that is correct.
Old August 24th, 2007, 02:16 PM   #6
Ok, i resolved that nvidia problem (seems like my recently "for bioshock" released driver wasn't all that "new"...so i dlded the standard drivers and it worked).
Could you tell me when that "fix" is released? Thanks :)
Chris
Old August 25th, 2007, 10:23 PM   #7
When will this fix be released, i am waiting for it, can't work without it.
Old August 25th, 2007, 10:37 PM   #8
CTO, CineForm Inc.
It was released this morning on this forum. Check out my post "Sneak peek on the new builds."
