Moving Titles in Vegas 7.0? at DVinfo.net
Old July 26th, 2007, 05:39 PM   #1
Is there a way to simply move/animate text around just with Vegas? Thanks.
Glenn Gipson is offline   Reply With Quote
Old July 26th, 2007, 06:51 PM   #2
I followed this info from off of a message board:
"Basically Spot is saying to create your text/title and while in the Placement tab, position it off the screen to the right.
Then, in the timeline at the bottom of that same dialog box, put your cursor all the way to the right (or end of the timeline) and click (you should see a vertical line that is blinking)
Then, grab your text/title again and move it all the way to the left (this will create a keyframe for you). Close the dialog box and hit play and you should see your text scroll from right to left."
Problem is, how do I get the title to go from left and right in an even manner?
Old July 26th, 2007, 08:17 PM   #3
when you move the title to the ending side and go to set your keyframe you can use either a numeric value to set the position of the last keyframe OR you can click on the position box and use the arrow keys to position the box where you want it
HTHs
Don
Old July 26th, 2007, 08:45 PM   #4
For example, to move the default text (Sample Text @ 72 pt.) from right to left:
In the Placement tab, set the X value of the first keyframe to +1.5 (text is off screen right);
Set the X value of the last keyframe to -1.5 (text is off screen left).
Play it and you'll see the text move right to left.
You can experiment with placing different letters in different positions and on different tracks.
Check out Matthew Chaboud's site (he's a poster here) for some examples of what you can do with text, specifically the ones at the bottom of this page.
Old July 27th, 2007, 05:59 AM   #5
Maybe this can help, has pictures to go along with the instructions. It deals with images but same principal can be applied to text:
http://www.wideopenwest.com/~wvg/tutorial-14.htm
C.M. de la Vega is offline   Reply With Quote
Old July 27th, 2007, 09:26 AM   #6
Another tip for text (thanks to Douglas Spotted Eagle for this), especially if you plan to zoom in on it, is to double its size when you first open the text FX window.
Look in the upper left corner and change it from 720 x 480 (for NTSC) to 1440 x 960.
Adjust as necessary for PAL or HDV.
Mike Kujbida is offline   Reply
