Achieving true half-speed slow mo through HD-SD conversion at DVinfo.net
Old July 22nd, 2007, 11:28 AM   #1
Guest
Posts: n/a
I've been pondering, is it possible to shoot footage in 1080i, then deinterlace to have two separate 540-lined fields, which can then be converted to SD progressive frames, thus creating half-speed motion but in SD?
The only problem I foresee here is that 540 lines is NTSC and I need PAL...
Old July 22nd, 2007, 11:33 AM   #2
Hi Jonny and welcome to DVinfo! I guess it depends on your software, but suspect you'll get something very close to what you describe by slowing down your 1080i footage 50% in your NLE, then downconverting the results to standard definition.
Old July 22nd, 2007, 03:27 PM   #3
Guest
Posts: n/a
So it'll definitely render each field as one progressive frame?
I'll be using Sony Vegas no doubt, if I were ever to edit any HD (initially)... would it work in this?
Jonny
Old July 22nd, 2007, 03:40 PM   #4
Jonny: I've moved your thread to our Vegas forum since that's a better place to get an answer. I'm on the Mac myself...
Old July 24th, 2007, 06:15 AM   #5
Guest
Posts: n/a
okay, thanks
Old July 24th, 2007, 03:54 PM   #6
Super Smooth Slow Motion
A more general slow motion can be achieved using some functions in AVISynth, MVTools. This uses motion compensation techniques to create the frames required.
I have slowed down surfing and snowboarding by a factor of 10 with good results for SD video. I generally convert interlaced to progressive. I have yet to try it on footage from my new HD video camera, but AVISynth should will handle that.
Last edited by Douglas Spotted Eagle; July 24th, 2007 at 06:22 PM. Reason: Removed links to Doom Forums
Peter Vann is offline   Reply With Quote
Old July 25th, 2007, 06:58 PM   #7
Guest
Posts: n/a
So does AVISynth do that, take each field from an HD frame and convert them into individual SD progressive frames?
Old July 25th, 2007, 07:18 PM   #8
You can create 60P in Vegas converting each field to a frame:
1) Download and install Mike Crash Smart Deinterlace filter: http://www.mikecrash.com/modules.php...p=getit&lid=51
(All his filters: http://www.mikecrash.com/modules.php...p=getit&lid=53 )
2) Create a 60P (59.940) project
- Field Order: None (progressive scan)
- Deinterlace method: None
3) Switches
- Smart Resample
4) Apply the Mike Crash Smart Deinterlace filter to the track
5) Render as 60P
John McManimie is offline   Reply With Quote
Old July 26th, 2007, 11:07 AM   #9
Guest
Posts: n/a
3) Switches
- Smart Resample
5) Render as 60P
Thanks very much :D
Old July 27th, 2007, 06:16 AM   #10
Guest
Posts: n/a
Oh just another thought on that - you say 60P, so I'm assuming you're working in NTSC - I'm working with PAL, will there be any conflict in the fact that the resolution will be 540 lines as opposed to 576?
Old July 28th, 2007, 03:02 PM   #11
Just create and render a "50.000 (Double Pal)" project (aka 50P) instead. I don't think you'll notice the difference in resolution. By the way, if you know ahead of time that your intended target is slow-motion 50P, you might try to shooting with a shutter speed like 1/100 rather than 1/50.
Old July 29th, 2007, 01:05 PM   #12
Guest
Posts: n/a
Ahh nice one, good point. Cheers for reminding me. :)
Old August 3rd, 2007, 05:52 AM   #13
Guest
Posts: n/a
ignore this
Old August 3rd, 2007, 08:41 AM   #14
Guest
Posts: n/a
ignore this too
Last edited by Guest; August 3rd, 2007 at 09:21 AM. Reason: Sod's law, it works now
