DVD 4 won't burn at DVinfo.net
Old July 16th, 2007, 11:10 PM   #1
DVD 4 won't burn
Just installed Dvd 4, first burn didn't. But the menu I had chosen did. The second disc does the same the menu burns and the prompt changes to Burning Video the estimated time just proceeds to add and add. On the second disc I ejected and reloaded the disc, DVD 4 gave me a error message and then proceeded to burn the disc? I then tried again with a preprocessed DVD. It now burns the menu and goes to burn the video. Where yet again it just proceeds to add to the length of time for completion of burning.
It is a puzzlement. I have noticed similar problems on the Sony home forum, the answer there was process the info and video, then use Nero to process to a ISO image and burn the disc that way.
Any help will be enthusiasticly read.
Thanks in advance
Carl West
Carl West is offline   Reply With Quote
Old July 17th, 2007, 12:45 AM   #2
Check to see if your burner has a firmware update from the manufacturer.
Canon XHA1, SGpro,Flip,FF, RR Mattebox, Nebtek V-R70p-HDA with Canon, Nikkor Primes 24mm f2.8, 28mm f2.8, 35mm f2.0, 50mm f1.4, 85mm f1.4, 105mm f1.8, 135mm f2.0, and 300mm f4.0.
Cary Lee is offline   Reply With Quote
Old July 17th, 2007, 07:20 AM   #3
Sponsor: JET DV
Another option is the PREPARE in DVD Architect and then BURN is some other program (i.e. Nero, Record Now, etc...)
Old July 17th, 2007, 07:54 AM   #4
If you are a windows user save yourself a bunch of headaches and get this free program to burn with
CD Burner XP Pro
http://www.cdburnerxp.se/
I replaced all of my cd burning applications with this, it does it all.
Martin Smith is offline   Reply With Quote
Old July 17th, 2007, 10:43 AM   #5
I never had any problems burning...you might check to make sure there is no breaks in the timeline. If there is a gap between you're menu and footage that may be the culprit. OR your audio is not synced up correctly to the footage to cause this hiccup in burning. I also bring in my footage in two separate files. One as Mpeg-2 for the video and a separate file for the audio.
Old July 17th, 2007, 09:47 PM   #6
So far the suggestion of updating the burners firmware seems to have worked.
Thanks for everybodys advice. I'll go back to reading the old forum archives to speed up my learning curve.
Carl
