Is it possible to individually assign a layer mask to an event FX? at DVinfo.net
Old July 13th, 2007, 10:33 PM   #1
I just learned how to use Bezier masks, but they seem to work on the whole layer, not individual events.
Emre Safak is offline   Reply With Quote
Old July 13th, 2007, 11:26 PM   #2
Bezier masks work *only* on an event. The only way to access a Bezier mask is via Pan/Crop, which cannot be applied to an entire track/layer.
Maybe I misunderstood your question?
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old July 14th, 2007, 09:50 AM   #3
Let's say I have several FX applied to a clip. How do I keyframe the mask for each FX?
Old July 15th, 2007, 02:23 AM   #4
Old Boot
Are you saying a MASK = a FX? Are you using the term "FX" as being a "MASK"? If this is the case then an Event can support many FXs. In which case, use the Keyframer Timeline and apply the FX parameters there.
But maybe I have misunderstood your question? Or maybe you have discovered yet another way of doing things!
I have never been able to apply a Bezier Mask to a whole Track. But I can apply a Bezier Mask to a Nested Veg project that I have imported to take UP a whole track. And there again, I AM using the Bezier Mask on the Nested Veg - which in this case is treated AS an Event.
Grazie
Old July 15th, 2007, 08:35 AM   #5
I wonder if I am using the wrong terms! What I want to do is to have FX1 apply to one portion of the screen, and FX2 apply to another portion of the screen, then I want to animate these portions with key frames. Both FX are associated with one clip.
I use mask to mean "portion of the screen".
Old July 15th, 2007, 09:54 AM   #6
Old Boot
Ah! Now I DO understand what you are wishing to achieve. No, I don't know of a way to do that - within ONE Event.
So:
1] - Track1 Event1 FX1 with Mask1
2] - Track2 Event1 FX2 with Mask2
This ways you've got complete control over the detail of the piece.
This is the way I would do it!
Grazie
Old July 15th, 2007, 10:30 AM   #7
Assuming you're talking about using bezier FX only, I agree with Grazie.
I did this last year on a chromakey that (due to sloppy lighting) required up to 3 masks to get rid of the crap portions of the backdrop :-(
Mike Kujbida is offline   Reply
