Converting to iPod's higher res at DVinfo.net
Old July 10th, 2007, 07:52 AM   #1
I know Vegas has a template for the iPod, but it's the iPod's old resolution (320x240). Not the now supported (since September 2006) 640x480. When I try and change the resolution and bitrate to match I get a file that iTunes will play but won't sync to the iPod. If I attempt to use the "convert to ipod" feature in iTunes I get a file with just sound.
How do I use Vegas 7 to convert to an iPod at higher resolution like 640x360? I don't want to be stuck with my optimized for iPod videos at only 320x240.
ScapeFilms.com | My Photography | IMDB Profile
Mike Tesh is offline   Reply With Quote
Old July 10th, 2007, 09:03 AM   #2
Vegas also has a template for 640x480. Just look in the same dropdown as you see the 320.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old July 10th, 2007, 09:07 AM   #3
All it shows is Default and Apple iPod Video.
Old July 10th, 2007, 09:33 AM   #4
Which build of Vegas 7 are you using? I don't have anything older than 7d within arms reach, and too lazy to run to another floor to check older machines. 7d has two iPod templates.
Douglas Spotted Eagle is offline   Reply
