Vegas Video discussions from 2004 (Q3Q4) - Page 95 at DVinfo.net
Old November 14th, 2004, 08:33 PM   #1411
Sponsor: JET DV
That's one of the new features in Vegas 5. Go to Options - Preferences and uncheck the "Allow edit cursor to be dragged" and see if it works as you expect.
Edward Troxel is offline
Old November 15th, 2004, 02:37 AM   #1412
Vegas 5's improved mpeg2 encoding
I'm reading the magazine Sony mails out to learn more about my new software. (I wish I was kidding. :) Can someone explain the following in really plain language, please?
"Vegas 5 software features improved, high-quality 2-pass VBR MPEG-2 encoding for DVD...Enhancements from the previous version include 4:2:2 High profile/Main level, and Transport stream support."
Basically, are the days gone that I send nice-looking SD video through an MPEG-2 render just to be disappointed with the dvds? I'm asking because at the moment I'm finishing up a little project at home--still on Vegas 4. If there's a big enough difference I'll move it to the pc in town with V5 and put up with another nine-hour render.
Lorinda Norton is offline
Old November 15th, 2004, 04:51 AM   #1413
Another Audio Question
Ok,
Let's say I have a cut from a medium shot to a close up shot.
Now the medium shot has good sound, but when I cut to the close up shot, the audio becomes different in the dialogue, louder. Is there a way to tell so that it can match. Or is it just adjusting the volume of the close up shot to the medium shot?
"Don't settle for the one you can live with, wait for the one you can't live without"
Matt Woodson is offline
Old November 15th, 2004, 08:54 AM   #1414
Sponsor: JET DV
Are you changing audio to the other camera when you switch the shots? If you are, why not let the first camera's audio continue under the second camera's video?
Old November 15th, 2004, 08:57 AM   #1415
Sponsor: JET DV
There were several improvements made to the DVD encoder between Vegas 4 and Vegas 5. The one most people were really looking for was the ability to do 2-pass VBR. This tells the encoder to go through the video twice - once looking at the video and a second time encoding the video. This allows for a better quality encode.
Old November 15th, 2004, 11:23 AM   #1416
<<<-- Originally posted by Edward Troxel : Are you changing audio to the other camera when you switch the shots? If you are, why not let the first camera's audio continue under the second camera's video? -->>>
No, the audio wasn't changed but the mic was closer to the close up shot when we shot it.
I've seen a test of what I have so far on dvd, when some scenes from medium shots cut to the character's close up shot, you can tell that the sound is louder, or more upfront. Don't know how to explain it. It just doesn't match.
Old November 15th, 2004, 01:22 PM   #1417
This might not be the proper question on this topic, but:
what does the DVD architect do? I mean, I can use AVIs into DVDA2 and then compile the DVD but I cannot find any options on the MPEG2 encoding...
Cosmin Rotaru
Cosmin Rotaru is offline
Old November 15th, 2004, 03:23 PM   #1418
Sponsor: JET DV
You can give DVDA an AVI file and it will automatically convert it to MPEG2 and AC3 for you. However, you get much less control over the settings which is why most people recommend encoding in Vegas instead.
The real purpose of DVDA is to author the DVD (create the menus and how the items interrelate). It will then create the required files for burning to a DVD. You can then burn with it or some other program.
Old November 15th, 2004, 05:27 PM   #1419
A/B Type editing in vegas?
I'm fooling around a bit with vegas, and so far I like what I see. I'm sure I could get used to doing all my fx transitions on one line, but is there any way to do a dissolve or something like that from one track to another? Sort of along the lines of premiere, etc?
Kevin James is offline
Old November 15th, 2004, 06:22 PM   #1420
Yes, you can transition between tracks, but if what your after is a more Premier-like representation, right-clik on the track header and choose Expand Track Layers.
Gary
Gary Kleiner is offline
Old November 15th, 2004, 07:23 PM   #1421
Flashing Text
Hi guys,
getting my feet wet learning Vegas 5 and having a blast.
I have this instant replay i'm creating in vegas, slowing it down and it looks great. Right now it says "Instant Replay" but i thought it would be nice if it flashed. Does any here know how to make it and control the flashing speed?
andy
Tim Kay is offline
Old November 15th, 2004, 08:15 PM   #1422
Thank you! Much less cluttered to my premire trained eyes!
Old November 15th, 2004, 08:39 PM   #1423
Chop up the text with the s key. Delete every other slice.
Gary
Old November 15th, 2004, 09:30 PM   #1424
Sponsor: JET DV
Kevin, keep trying as a single track too. Eventually you'll come to see how cluttered having TWO tracks when you only need ONE really is!
Old November 16th, 2004, 04:11 AM   #1425
cAN'T find the "s" key
Funny, i looked for the "slice" feature but i couldn't find it. So i did an index search and nothing came up. Does Vegas use another word maybe? Right now i'm using the media generator for the text (the one named "text" in the left pane). Can this be sliced?
thanks,
tim
<<<-- Originally posted by Gary Kleiner : Chop up the text with the s key. Delete every other slice.
Gary -->>>
Tim Kay is offline
