Vegas Video discussions from 2004 (Q3Q4) - Page 92 at DVinfo.net
Old November 6th, 2004, 10:33 PM   #1366
Render to AVI files
Hello everyone. I am using Vegas 5.0. I want to render to AVI, I have about an hour and 10 minutes worth here. When I render it, it outputs to four separate AVI files that are around 4 GB each. Is there any way to tell it to save it to one file only?
Aaron Ferguson is offline
Old November 6th, 2004, 10:45 PM   #1367
Sponsor: JET DV
Yes. Format your hard drive as NTFS instead of FAT32. FAT32 has a 4 Gig file size limit.
Edward Troxel is offline
Old November 6th, 2004, 10:47 PM   #1368
As soon as I posted, it popped in to my head that that was probably the reason. Thanks!
Old November 7th, 2004, 06:19 AM   #1369
RED Code Chef
Perhaps do a re-install of Vegas to make sure it has all the proper
components installed?
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old November 7th, 2004, 07:40 AM   #1370
Registration Incomplete -- contact Admin.
The Best Settings For Vegas
Hey everyone i was wondering what was the perfect setting in vegas 4.0 in frame rate, and all that stuff.
Young Filmer is offline
Old November 7th, 2004, 07:52 AM   #1371
RED Code Chef
We cannot answer your question. Best for what? Framerate has
nothing to do with your NLE but the camera you used and at what
framerate it shot your footage. "Best" is a very subjective term
and what I find best might not be best for you. You are going to
have to do a lot more explaining what you are looking for....
In the end experimenting with settings and seeing what that does
to the look of your footage is usually far more helpfull as well
then simply using settings that someone else gives you. Ofcourse
there a few basic settings, but those should be pretty obvious.
Old November 7th, 2004, 08:09 AM   #1372
Ok
OK well i am using a very crappy camera right know Jvc grdvm90u but will be getiing on of the canon xl1s soon so i am trying to find the best way to get the look of film in vegas 4.0 when filming off of a dv camera that is not 24p. hope this helps.
The JVC records at 29fps
Old November 7th, 2004, 08:45 AM   #1373
RED Code Chef
Please take a look into our "Towards a Film Look using DV" forum.
It has lengthy threads on this very topic. There aren't any easy
setting etc. to get a "film look". The XL1S is a nice camera and
most people seem to agree that switching it to frame mode (make
sure your Vegas project settings are set to progressive) helps in
giving the "film look". Besides that it comes down to:
- having a good story
- actors
- lighting
- audio (recording/mixing)
- composition (camera movement etc.)
- editing
And then some other stuff like color correction and so forth.
In vegas you choose "NTSC DV" as the project template for the
JVC. You do the same for the XL1S, but change the interlaced
setting from bottom field to none (progressive) when shooting
in frame mode.
Old November 7th, 2004, 11:07 AM   #1374
well...wat i ended up doing was just going thru the whole wedding and watching my audio levels and adjusting manually. I was up in a balcony and the organ was blasting - but of course the pastor and bride/groom where all the way across the chapel w/no mic, etc.
i just made sure i wasnt going over -12 ever and tried to average it out as best i could for all the speakers. seems pretty decent when viewed on average tv off of DVD.
Trey Perrone
Trey Perrone is offline
Old November 7th, 2004, 12:11 PM   #1375
How do you burn in a music CD the audio in vegas?
Hi everybody...I did some audio edition in Vegas , and now I want to burn in a Cd music the audio tracks exactly as I putted in the time line..How can I do this? Thanks...
Julio Laffont is offline
Old November 7th, 2004, 12:34 PM   #1376
Whoever told you -12 was "DV legal" was in error. Check this out:
http://www.creativemac.com/2003/02_f..._dv_levels.htm
John
John Cline is offline
Old November 7th, 2004, 02:39 PM   #1377
Vegas manual in Spanish/Espanol
Makes for heavy reading in whatever language, especailly if it's not your native language. Can anybody help with Vegas 5 support in spanish?
Colin Rayner is offline
Old November 7th, 2004, 03:29 PM   #1378
Sponsor: JET DV
I have that process documented in my newsletter. Just click the link under my name.
Old November 7th, 2004, 03:32 PM   #1379
Sponsor: JET DV
As far as I know, the manual is English only.
Old November 7th, 2004, 03:38 PM   #1380
Thanks for that Edward, I thought as much, the Sony media site didn't offer anything other than English.......
