Vegas Video discussions from 2004 (Q3Q4) - Page 57 at DVinfo.net
Old September 12th, 2004, 07:32 PM   #841
Michael,
Thanks for sharing this. I like the short film as well, with regard to cinematography and lighting.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old September 13th, 2004, 04:49 AM   #842
Clip Pan Crop ruler
anyone know how to get it up on Vegas 5??
for the life of me i cant find it.......
Peter Jefferson is offline
Old September 13th, 2004, 07:19 AM   #843
Sponsor: JET DV
I does not appear to be there. I guess I never missed it because I never used it in Vegas 4.
Edward Troxel is offline
Old September 13th, 2004, 08:41 AM   #844
Arm for record
Have had a lot of fun recording into tracks - Mixing board with various intruments attached going into sound card going into Vegas. Interestingly it will not record to the drive that I keep
Vegas files in it will only work on the drive that has the actual
Vegas progam on. the manual says you can tell it where to record
the files to but it will not work on a drive that does not have the
program on it. No big deal but a little bothersome for media management.
Michael Best is offline
Old September 13th, 2004, 09:12 AM   #845
I occurs to me that I always find the most complicated solution to a problem :-)
Thanks, Randall!
Peter Koller
Vienna, Austria http://www.kop11.com
Peter Koller is offline
Old September 13th, 2004, 09:50 AM   #846
I do the same thing sometimes Peter!
I just posted a short tutorial on this in the Vegas FAQ at the following URL:
How do I create a Widescreen video from 4:3 source material?
Randall
Randall Campbell is offline
Old September 13th, 2004, 10:15 AM   #847
Sponsor: JET DV
Have you set the setting to record to the other drive? That setting is in File - Properties under the Audio tab.
Old September 13th, 2004, 10:27 AM   #848
Indeed - It starts and immediately stops recording, the cursor
still moves down the timeline but nothing is recorded. There
is then a message at the bottom right of my computer screen
(not in Vegas) saying Write Failure, all data has been lost.
Old September 13th, 2004, 10:28 AM   #849
Excalibur 3
All I can say is WOW.....IF you thought multicam editing was fun in prior versions, version 3 has truly impressed me....
Thanks Edward
Mark A. Foley is offline
Old September 13th, 2004, 10:47 AM   #850
On behalf of Edward and myself...you're welcome.
We really enjoy knowing that our products are truly helpful to our fellow Vegas editors.
Gary
Gary Kleiner is offline
Old September 13th, 2004, 10:50 AM   #851
Gary,
I forgot to put your name in there...by no means intentional...I truly was blown away by the capability of version 3....best 30 bucks I've spent in sometime....
Mark
Old September 13th, 2004, 11:14 AM   #852
how do i import a large frame size jpeg to standard frame size project?
i want to import a jpeg sequence with a frame size of 1350x720 into a project which uses standard PAL frame size of 576x720. when i do so, vegas distorts the image of the jpeg sequence so that it fits into 576x720.
is it possible to import the jpeg sequence in such a way that it keeps it's original frame size (1350x720)? later i intend to crop the jpeg sequence in vegas to 576x720.
adi
Adi Head is offline
Old September 13th, 2004, 12:35 PM   #853
Sponsor: JET DV
Open Pan/Crop, Right-click the image, and you will see several different options. The one most used is "Match Output Aspect". You can also manually adjust the settings as needed.
Old September 13th, 2004, 01:03 PM   #854
hi ed. i think you misunderstood me. maybe i didn't explain the problem properly.
i know how to crop.
my problem is: when importing the larger frame, vegas autiomatically "squeezes" the large frame (1350x720) to the standard frame size (576x720) and distorts the image by doing so.
i want to import the larger file as is. but can't find how to do it.
Adi Head is offline
Old September 13th, 2004, 01:20 PM   #855
Sponsor: JET DV
You're right - I wasn't thinking of the File - Open - Image Sequence. However, I think it might still work.
Import it, open Pan/Crop, Right-click the image, and choose "Match Output Aspect".
