Vegas Video discussions from 2004 (Q3Q4) - Page 30 at DVinfo.net
Old August 6th, 2004, 10:39 AM   #436
Sponsor: JET DV
It appears that if you use Pan/Crop to create the PIP, the transition will apply to the entire video frame. However, if you use Track Motion to create the PIP, the transition appears to only apply to the PIP. That's how it is testing out for me.
Edward Troxel is offline
Old August 6th, 2004, 04:28 PM   #437
Another V5 clip- this time a Wedding
mod please delete
Glen Elliott is offline
Old August 7th, 2004, 10:53 AM   #438
Static audio
Imported a cd track and most of it is just static, take it over to
sound forge and it sounds fine? Does the format need changed?
How would you do this? The disc plays normal on a player.
Michael Best is offline
Old August 7th, 2004, 10:57 AM   #439
Sponsor: JET DV
What type of file is it? My cd imports are WAV. What program did you use to import it? What if you render from SoundForge to a new WAV file?
Old August 7th, 2004, 11:04 AM   #440
Wow am I frustrated, I extracted from InstantWrite, Siren, and others, opened it in SoundForge. It plays parts, then silence,
but mostly loud static. I've tried importing right in Vegas. It just
a cd track from a local band burnt on a cd-r. I mean the file in the
media pool plays fine when sent to soundforge that's getting me
otherwise I'd of thought the file itself was messed up but Vegas
won't play it right, and that's the only place it won't play right.
The thumbnail for it shows a Winamp logo.
Old August 7th, 2004, 11:07 AM   #441
I also ran it through Acid
Old August 8th, 2004, 04:20 AM   #442
err.. wahts teh actaul disc.. some audio cds have copy protection which seems to be the case here coz the buzzin noise ur descibing sounds like the copy protection at work ...
Peter Jefferson is offline
Old August 8th, 2004, 09:21 AM   #443
No, it's just a basic cd-r recorded at a local studio, no protection.
Old August 8th, 2004, 11:23 AM   #444
"Moving the Grid"
Hey guys!
I have just ugraded to Sony Vegas 5.0 (from 4.0) and it is of course fantastic! However, I am having a slight problem with an aspect of the 'Event Pan/Crop' tool.
In Vegas 4.0, say I had opened an 'Event Pan/Crop' window, I could move the grid with the cursor keys on my keyboard which allowed me position precisely where I wanted the grid to go.
However, in Vegas 5.0, I am only able to move the grid using the mouse, or by typing in the relevant x,y etc values under the properties panel.
Is there a way I can get my cursors to function like they do in Vegas 4.0, so that they move the grid in minimal measures?
I know it sounds like a small problem, but I find it terribly annoying, as I like to have the frame panned and cropped precisely to my preference.
Hopefully somebody can shed some light on the situation!
Thanks!!
Sunny Dhinsey
Director - www.filmlore.tv
Sunny Dhinsey is offline
Old August 8th, 2004, 12:35 PM   #445
Sponsor: JET DV
Moving via keyboard arrows was returned in Vegas 5.0b. What version are you running?
Old August 8th, 2004, 12:51 PM   #446
I see! I am running version 5.0a, which explains the problem.
Is there a patch of some sort that I can download to get this problem sorted out?
Sunny Dhinsey
Old August 8th, 2004, 12:53 PM   #447
I think I've found the update at
http://mediasoftware.sonypictures.co...p2.asp?DID=496
I'm assuming this will solve the issue!
Thank you for your response Edward.
Sunny Dhinsey
Old August 8th, 2004, 01:29 PM   #448
Sponsor: JET DV
Yes, that is the proper link for the 5.0b download.
Old August 8th, 2004, 02:38 PM   #449
I downloaded and installed the Update and alas, my problem is solved!
I know it sounds like something Trivial, but I was prepared to resort back to Vegas 4.0 had there been no solution (!)
Thank you Edward!
Sunny Dhinsey
Old August 9th, 2004, 02:12 PM   #450
DC Metro, Northern Virginia to Baltimore Vegas user Group
A gent named Mickey Grackin and myself are trying to start up a DC Metro area Vegas User Group. Covering Northern VA, Washington DC, Maryland up to Baltimore (and points east to Anapolis). Anyone using Vegas for any reason is welcome.
If interested you can email him at
mgrackin@oicproductions.net
Joe Carney is offline
