Vegas Video discussions from 2004 (Q3Q4) - Page 2 at DVinfo.net
Old July 3rd, 2004, 03:02 PM   #16
Sponsor: JET DV
Support for dual layered burners was not added.
Edward Troxel is offline
Old July 3rd, 2004, 04:19 PM   #17
RED Code Chef
To what did you render? Which export settings did you use? What
where your project settings? Did you use best or good for exporting?
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old July 3rd, 2004, 04:27 PM   #18
Images: 32
- Project properties were all defaults - fresh install of Vegas 5.
- Only thing I changed was Good to Best.
- Rendered to DVDA MPEG2 and DVDA AC-3 Stereo.
- Edits: basic crossfades between clips.
I'll post some video, so you can see, it's very disconcerting to see your hard won video like that :-)
Michael Wisniewski is offline
Old July 3rd, 2004, 04:50 PM   #19
RED Code Chef
Default project settings don't say much since I don't know what
they are. It probably starts up as 4:3 NTSC, but it might not. It is
VERY important to what project settings you have.
Rendering to DVDA doesn't tell me much either. Which MPEG2
template did you use?
Old July 3rd, 2004, 07:20 PM   #20
Split Screen with Vegas 5
I'm trying to setup a split screen in Vegas 5 using a Media Generator, but I can't quite get it. This is what I'm doing:
3 Video tracks
Tracks 2 & 3 are my video that I want on the left side and right side, respectively.
Track 1 contains Media Generator/Checkerboard/Split Screen
No matter how I set the composite mode for each track I still can't get the desired effect, although I think this is where my problem lies.
Can you please tell me if this is correct and how the composite modes should be set? Thanks.
David Jasany is offline
Old July 3rd, 2004, 07:38 PM   #21
Media bin in Vegas Capture?
Just trudging through capturing 14 tapes for footage to compile my 2005 wedding demo DVD. I'm getting an accumulation of clips in the capture's "media bin. Is there a way to clear them from the bin? There are even clips in there from captures a while ago. I have the setting checked so that captured clips are NOT added to the media bin.
On another note- anyone ever wonder if mixing tapes ruined your heads- well...I'm going to find out. I just got a brand new Sony TRV-33 to do all my capturing. Like I said I have 14 tapes to capture....all different brands- some wet lube some dry. I'll let you know if the myth is indeed a myth or....not. Wish me luck. :)
Glen Elliott is offline
Old July 3rd, 2004, 09:29 PM   #22
Sponsor: JET DV
Track 1 composite mode: Multiply (Mask)
Add a "Mask Effect" to the actual mask OR track 1.
Old July 4th, 2004, 03:10 AM   #23
NetWorkRender<*sigh>i Wish
wouldn't this have been a decent setup.
http://insidecarolina.org/images/IMG_2109.JPG
stitchHost: AthlonXP 2800+ 1GBDDR
netwerkRenderMachines: Athlon 64 3000+ 512DDR, AthlonM 2800+ 512DDR, P4 2.4 512DDR
100 MB/s switch fullDuplex 100MB/s NIC setup
no programs, screensavers, antivirus, minimal driver load
.......but then i read that there was a limit of clients per license (2 i think?) gave up on the idea until some testing has been done and nothing is in the queue. can't plumb things up.
Trey Perrone
Trey Perrone is offline
Old July 4th, 2004, 03:43 AM   #24
RED Code Chef
Just select them and hit delete. If you are not at ease with this
system I suggest you try it out on a "capture" you don't care
about. This should only delete if from the bin and not from your disk.
Old July 4th, 2004, 04:35 AM   #25
RED Code Chef
Is there a question in there somewhere? With your current license
there is a limit of two render nodes indeed. But I'm not quite
sure what your problem is here. 3 computers will do more than
one will. And you can buy extra render only licenses so you can
expand to as many PC's as you want.
Have you read the Sony Vegas 5 Network rendering White Paper?
If not do so. You can find it here: http://mediasoftware.sonypictures.co...p2.asp?DID=515
Old July 4th, 2004, 05:40 AM   #26
Sponsor: JET DV
Just buy a second copy of Vegas and you can use SIX machines.
Old July 4th, 2004, 05:43 AM   #27
Sponsor: JET DV
What if you just go to "File - New"?
Old July 4th, 2004, 03:10 PM   #28
Thanks Edward, I'll give it a try. I assume the top track with the effect should be the parent, and the two video channels should both be a child.
Old July 4th, 2004, 03:33 PM   #29
Sponsor: JET DV
The TOP track is Parent, the MIDDLE track is Child, the THIRD track is back at the parent level.
Old July 4th, 2004, 04:08 PM   #30
xl1s records 'frame' mode. do you capture/render in 24fps or 30?
with footage that has been captured in xl1s's frame mode how do you capture into computer and then render to final DVD that is 'anamorphic'? i'm using vegas4 w/DVD-Arch1.0. will upgrade later on but this is what i'm working with now.
step1:
in vegas under capture's preferences, under analog device options you can set the 'custom frame rate'. should i set this for 29.97ntsc or 24film? does this analog device options affect DV tape captures?
step2:
under 'video track properties' (right click on video track to select properties), there is a media tab, under that do you select the field order as progressive or leave it at 'lower field first'?
step3:
under 'project properties' do you select field order as progressive or 'lower field first'?
step4:
when you are finished editing and you are select 'render as', do you choose ntsc24p or ntsc30fps?
bow wow wow
Yi Fong Yu is offline
