Vegas Video discussions from 2004 (Q3Q4) - Page 107 at DVinfo.net
Old December 3rd, 2004, 07:58 AM   #1591
hey Douglas,
would you mind if i used these for the Digital Media Festival to use within Vegas 5??
Im helping New Magic demo V5 and DVDA2 to people and im also doing showcase presentations in an auditorium (yup im nervous.. LOL) <Basically im the demo guy here in oz>
Mark from Newmagic has some footage, but id like to have a huge variety available if i may??
Pls let me know :)
Peter Jefferson is offline
Old December 3rd, 2004, 08:16 AM   #1592
go for it. As long as it's not an edited project to be broadcast...
Have a blast!
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old December 3rd, 2004, 08:41 AM   #1593
actually Im using the JVC HD10U, which will make a difference.
Mark Paschke is offline
Old December 3rd, 2004, 09:29 AM   #1594
Thank you Edward,
I found the way to get into the internal preference. By apply your method to it, I was able to customize the screen the way I wanted.
Huy Tuong is offline
Old December 3rd, 2004, 03:35 PM   #1595
Fred Retread
Excalibur and Video Track FX
I color corrected camera #2 to better match #1, but the corrections don't carry over when I run the MultiCam Wizard. Do I have to render camera#2's track to save the corrections before running the wizard?
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline
Old December 3rd, 2004, 04:19 PM   #1596
Sponsor: JET DV
Apply the effect to the EVENT instead of the TRACK. If applied to the event, it will be moved with the event to the Master Track. If applied to the track, it will remain on that track and all events moved to the Master track will NOT see it.
As an alternative, you can apply it to the MEDIA in the Media Pool. Just save a preset of the effect on the track and apply that preset to the clip in the Media Pool and you'll be done.
Edward Troxel is offline
Old December 3rd, 2004, 04:54 PM   #1597
Sony Vegas Pan/Crop
I was trying to apply pan-crop event on my still photo in Vegas. Everything works well, but...I have a photo mosaic image which is basically an image rendered out of many other images. When I try to zoom in on the image using pan-crop and keyframes the quality of the image degrades a lot. To test I zoomed in on the image in Photoshop and quality stays pretty much the same. So, is the problem in Vegas or my image. Also, I import image at original resolution 4000x3000px should I bring it down to 720? But then when I zoom in on the image the individual images become pixelated.
thanks,
Alex
Alex Kravets is offline
Old December 3rd, 2004, 05:37 PM   #1598
<<<-- Originally posted by Mark Paschke : actually Im using the JVC HD10U, which will make a difference. -->>>
Then set up a new template in exactly the same fashion as I outlined above, but with the following settings:
width: 1,280 height: 720
field order: none (progressive)
Pixel aspect ration: 1.0000 (square)
Frame rate: 29.97 (NTSC)
full frame resolution quality: Best
motion blur type: Gaussian
Deinterlace method: none
Save as JVC HD10u, so you can select the template from the template type dropdown list whenever you require it...
Steve Crisdale is offline
Old December 3rd, 2004, 08:07 PM   #1599
Thanks Much Steve ( as always)
I had donethis with these settings but I am still getting weird glitchy results, maybe TMPGe will fix this when it encodes
Old December 3rd, 2004, 10:29 PM   #1600
Sponsor: JET DV
If you are, indeed, zooming with Pan/Crop, you will be using the FULL resolution of the image.
If you, instead, are actually using Track Motion, you will be zooming in on the video frame instead resulting in a degraded image.
Old December 4th, 2004, 05:46 AM   #1601
RED Code Chef
Wavelet is neat, but wasn't fractal compression the way to go for
great compression levels without (too) much quality loss? I
remember dabbling with fractal algorithms a couple of years ago,
also for image blowup (which looked real good, but was painfully
slow).
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old December 4th, 2004, 06:20 AM   #1602
<<<-- Originally posted by Mark Paschke : Thanks Much Steve ( as always)
I had donethis with these settings but I am still getting weird glitchy results, maybe TMPGe will fix this when it encodes -->>>
Have you tried just using the CFHD *.avi's that AspectHD creates rather than encoding uncompressed in Vegas?
I've had a problem with getting ConnectHD (uses the same underlying codec as AspectHD) to work at the moment so I can't replicate your circumstamce, but I believe the CFHD avi's should load into TMPGEnc. According to Cineform's product info they should anyway......
Old December 4th, 2004, 10:06 AM   #1603
groovy thanks for that mate!!!
Actually its only foir live demos on some Vegas pods we've built. Were running the new HDV plugin for capture and project settings.
Its still in its early stages... i think to early right now as its quite system draining.. heres hoping they fix the cpu/ram resource issue in V6... at teh moment vegas isnt using as much of teh system grunt as it could..
thanks again for the loan, i;ll let u know how it goes!
Old December 4th, 2004, 10:10 AM   #1604
Convert the files using the Demo version of Cineform's codec, or convert the media to Huffyuv.
If you use Cineform, getting 25p or 50i playback is crazy simple. Native m2t streams will NEVER playback at full rate on today's computers, MPEG is just simply cruel.
Old December 4th, 2004, 10:52 AM   #1605
Yep Cineform works good,
The new TMPGe is so fast its unbelievable as compared to last version
