Help HDV 60i Freezes at DVinfo.net
Old June 20th, 2007, 04:23 AM   #1
Hi guys,
I have a 10 minutes footage in Vegas properties I choosed HDV 60i and redered it as Mpeg-2.
However I noticed that it is choppy and freezes during play back. I then changed the properties to NTSC 720 and was OK . I never had this problem with HDV 30F? I use XHA1 Canon. I have E6600 CPU and the system is only 2 months old.
Please assist me with this issue.
Thanks in advance
Matthew
Canon XHA1, Brevis 35mm, Manfrotto 028,501,Vegas Pro 10e
Matthew Amirkhani is offline   Reply With Quote
Old June 20th, 2007, 08:07 AM   #2
your system can't handle the HD MPEG decode, apparently. You're playing it from a DVD? I'd expect it to chop. From HDD, it should play with out chop, however. Are you running antivirus in the background by chance?
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old June 20th, 2007, 08:12 AM   #3
Hi DSE,
I have no Antivirus on the system and I am not running it from DVD.I choosed HDV 60i rendered it as Mpeg-2 and Default setting.
DSE,Why it dosen't do it in 30F mode?I don't understand am I missing something here should I de-interlace it?
Matthew
