Vegas 7 project file at DVinfo.net
Old June 11th, 2007, 08:47 AM   #1
I just installed Vegas 6 + the upgrade to 7.0 ($249 from B&H).
First I uninstalled the Trial version (7d) I was using. Then I installed 6, then the 7 upgrade from the CDs, and finally I upgraded with the 7.0d version downloaded from Sony's website. Everything appears fine, however, two quick questions:
1. When I look at my project files, under Type they say "Sony Vegas 7.0 TRIAL." Is this a problem?
2. Do I have to leave Vegas 6.0 installed on my computer? I plan to only use 7d so it's a waste of space to keep 6 installed.
Ben Hayflick is offline   Reply With Quote
Old June 13th, 2007, 09:29 AM   #2
Hi Ben,
Only a guess but if you save the files again in the full v7 does the trial info go away? I'm just thinking that maybe these are files you saved when running the trial.
Not aware of any reason why you would need to retain 6. I keep previous versions for a few months until I'm happy with the update then ditch them.
Ian . . .
Ian Stark is offline   Reply With Quote
Old June 13th, 2007, 03:16 PM   #3
Sponsor: JET DV
You went through a lot of unnecessary work. Instead of all of the uninstalling and installing, simply entering the Vegas 7 code in the original 7.0d demo installation would have been sufficient.
Old June 13th, 2007, 05:23 PM   #4
Also, Vegas is up to version 7.0e. You might want to just download and install that to bring yourself current.
Guy Bruner is offline   Reply With Quote
Old June 13th, 2007, 09:44 PM   #5
Ian, nope. But a fresh install did the trick. The project files are now "Sony Vegas 7.0." I've deleted 6.0 (and the media manager) and all's well.
Edward, where were you when I needed you most? ;)
Guy, I've heard bad things about 7e. Not the case?
Old June 14th, 2007, 05:54 AM   #6
Ben,
I haven't had problems with 7.0e, except I can't edit my AVCHD files with it because Sony is procrastinating on including Panasonic AVCHD. What kind of problems are being reported...and where. I've not seen any complaints.
Old June 14th, 2007, 11:36 AM   #7
I read that people who'd upgraded from 7d to 7e were having all kinds of problems (crashes and so on - can't remember what exactly). I read that either on the Vegas forums on dvinfo.net and/or dvxuser.com. People who'd installed 7e then wanted to roll back to 7d, which was problematic until somebody posted a link to all the versions of Vegas somewhere on Sony's site.
So I just decided to stick with 7d, which eveyone seemed to say was the most solid version. Should I reconsider? What advantage does 7e bring over 7d?
Old June 14th, 2007, 11:42 AM   #8
Nothing significant unless you want to edit Sony AVCHD files.
Old June 14th, 2007, 11:45 AM   #9
Thanks. I've got no need for AVCHD for the moment (Canon XHA1 owner).
Old June 14th, 2007, 12:23 PM   #10
I upgraded to E from D and every time I'd load up a project, one that I had started in D, E would freeze up while building the peaks for all the audio. I switched back to D, and haven't had a problem since.
SB
Steven Bills is offline   Reply
