HDV Captured with Vegas from Sony FX1 at DVinfo.net
Old June 11th, 2007, 04:04 AM   #1
Now I am trying to edit.
I capture the video... but its in a highly compressed .m2t file
My question.... how can I re-encode this video into a usable file.... for my p4 computer.
I have 4 terrabytes...space is no factor...
but the m2t file is too compressed in Vegas for me to really work with it.
THANKS!
I produce High Quality content with My Certain Style... I cover South Padre, TX to Tampa Bay, FL
FYI: That includes... Corpus Christi, Galveston, Houston, Beaumont/ Lake Charles, Lafayette, Baton Rouge, New Orleans, Biloxi, Mobile, Penscola, Ft. Walton, Panama City... Any every little city and town in between.
If you need anything, Let's talk...
Brent Marks is offline   Reply With Quote
Old June 11th, 2007, 10:10 AM   #2
Not sure what you intend to do and what you mean by "useable" but you could always re-encode into the Cineform Codec which creates a cineform .avi file.
Jon
Jon McGuffin is offline   Reply With Quote
Old June 11th, 2007, 11:23 AM   #3
Your P4 should be just fine for editing HDV natively - I also use a P4 @ 3.0 GHz with 1GB RAM and an old 64 MB video card, and it's working just fine, with real time playback and no jitter/stutter on the Premire Pro timeline.
Depending on what you intend to do with your footage, you can work with it as is, or you can decompress it into any number of other formats from DV to uncompressed using mostly free software like MPEG Streamclip or VirtualDub.
Ervin Farkas
www.AtlantaLegalVideo.com
Old June 12th, 2007, 11:29 AM   #4
almost fine...
A p4 will almost be fine..... right up until you start layering on the color correction, contrast changes, and text overlays with transparency effects. Add all taht and Vegas will slow way down. You find you need to switch your preview window to 1/4 size and then down to draft quality just to keep up the frame rate.
I have edited native HDV footage in m2t format from my FX1 on both a Core 2 Duo with 2GB of DDR2 and on a P4HT@3GHz with 2.5GB of DDR2.
Jason Robinson is offline   Reply
