Newbie Slow show help setting auto crossfades at DVinfo.net
Old May 20th, 2007, 08:45 AM   #1
Newbie Slide show - help setting auto crossfades
I followed the help and it was okay but for whatever reason it wont set the auto crossfade but does everything else.
Options/Preference/Edit then "Automatically overlap multiple selected media when added" and I check that off and then select the amount of seconds and to 1 second or 5 seconds. Above under "new still image length" I set to 5 or 10 seconds....BUT
It does all this fine and the overlaps are all right, but is there a way to have it default at all a basic crossfade or do I have to manually add that effect? Right now it just does the standard cut from photo to photo whereas I wanted to have all be a crossfade. Help!
Chris Corn is offline   Reply With Quote
Old May 20th, 2007, 10:18 AM   #2
If Automatic Crossfades hasn't been selected, this is what will happen to you.
It's a tool bar icon that's also found under Options - Automatic Crosssfades.
Shortcut is Ctrl+Shift+X.
Old May 20th, 2007, 04:29 PM   #3
Genius! Thanky.
