Rendering Options at DVinfo.net
Old May 9th, 2007, 01:26 PM   #1
Rendering Options
This is probably a simple question but I'm curious. In Vegas is it better to PRE-render a time-line at the best quality before rendering out as a MPG-2 or is there really no difference from straight rendering to MPG-2 from the time-line?
Michael Tobias is offline   Reply With Quote
Old May 9th, 2007, 04:30 PM   #2
I see no reason to do a pre-render so I render direct to MPEG-2 from the timeline.
If the video is over 80 min., I'll tweak the bitrate to get the most out of it.
Old May 9th, 2007, 05:07 PM   #3
It depends on which format you use for your pre-renders. If it's DV, then there is going to be a colorspace conversion issue.
DV is 4:1:1 and DVD MPEG2 is 4:2:0, if you render MPEG2 from DV, you end up with 4:1:0. 4:1:0 means that you will only have 12.5% of your original DV chroma resolution left on the DVD. Vegas generates all media and titles at full 4:4:4, so if you render directly from the timeline, all generated media and titles will end up at 4:2:0 on the DVD, although DV media will still take the 4:1:0 hit.
That's the long answer, the short answer is render directly from the timeline.
John
John Cline is offline   Reply With Quote
Old May 9th, 2007, 07:47 PM   #4
Jubal 28
No reason to do a pre-render.
David Jimerson is offline   Reply With Quote
Old May 10th, 2007, 11:44 AM   #5
Thanks to all for the information. The color space conversion makes particular sense.
