Vegas error message - anyone know what this means? at DVinfo.net
Old March 21st, 2007, 08:47 PM   #1
I get this message every time I close out of Vegas. Anyone know what it means?
<The instruction at "Ox7c9105f8" referenced memory at "0x09070010". The memory could not be "read. Click OK to terminate the program>
Anything special I need to know if I reinstall Vegas? I guess I've been hesitant because I'm not sure if there are any restrictions regarding how many times one can install, license, etc.
BTW -- can I install on more than one computer? (ie, my laptop as well as my main machine)
James Binder is offline   Reply With Quote
Old March 21st, 2007, 11:12 PM   #2
<The instruction at "Ox7c9105f8" referenced memory at "0x09070010". The memory could not be "read. Click OK to terminate the program> ......
Hi, you have not indicated what type and spec of machine you have.
There could be a number of issues.
You could have some bad ram. You can do a test with a free app from here ...
http://www.computerhope.com/issues/ch000708.htm
Cheers,
Robert
Robert Garvey Photographer
www.garvey.com.au
Robert Garvey is offline   Reply With Quote
Old March 21st, 2007, 11:47 PM   #3
Sorry --
Pentium(R) duo core 3.2 GHz
3 Gigs RAM
Vegas 7.0d
Old March 22nd, 2007, 07:09 AM   #4
You certainly can. Here's the officical response:
Knowledgebase Answer ID 455
Question
Can I run my Sony Media Software application on more than one PC?
Answer
Our licensing agreement permits you to install the software on as many machines as you own, as long as you are not running the programs at the same time. For instance, you can install the software on your home machine and on your laptop. You are not allowed to install the software on multiple machines if you are going to be using them simultaneously, such as in a home studio setting. If you are going to run the software concurrently on more than one machine, you would need to purchase a separate license for each computer.
Note that when you install the software on a different computer you will need to complete the registration process again. Register the software as you did the first time to unlock the program on each machine. You can register online directly within the software, via the phone, or on our website through our online form.
Old March 23rd, 2007, 03:07 PM   #5
Thanks for the info guys --
Anyone know if I will have any trouble reinstalling the software in regard to the registration process? Meaning, I have already done so -- and when I reinstall, I'm guessing that I will have to do so again...
I'll suppose I'll try that first to see if I can get rid of the error message mentioned above...
Old March 23rd, 2007, 04:15 PM   #6
Nope. And if you do it online, it's almost instant :-)
The only time folks have run into problems is when it's been done numerous times. Even then, a quick phone call to Customer Support explaining things and you're good to go.
Mike Kujbida is offline   Reply
