DVDA 4.0 - Volume control ? at DVinfo.net
Old February 2nd, 2007, 01:12 PM   #1
I have 3 seperate MPEG2 files on one DVDA menu. One of them the audio is considerably lower than the other 2 when played. Is there a way on DVDA to boost the volume with out effecting the other 2 mpegs ?
I found that I can set the audio track to something other than the original via the set auido command, but have not found a place to simply give the volume a 3db boost..
Worst case I can just re-render the track in vegas (audio only) and then add it back in to DVDA. Was just hoping there would be an easier way in DVDA.
Any help would be appreciated.
SC
Steve Clee is offline   Reply With Quote
Old February 2nd, 2007, 01:15 PM   #2
That's the easiest (and, as far as I know, only) way to do it.
Old February 2nd, 2007, 03:42 PM   #3
I had the same issue and re-rendering was the only option. Plus it gives you the control to insure it comes out properly rather than trusting another source.
Bradley D Barber is offline   Reply With Quote
Old February 2nd, 2007, 04:12 PM   #4
Fair enough, by rendering only the audio it doesnt take much time. Was just curious if there was an in house way in DVDA...
Thanks for the replies
SC
