uncompressed MOV file at DVinfo.net
Old January 24th, 2007, 12:03 AM   #1
A stock footage web site I am thinking of working with wants all clips made into .mov files. I have tried using Vegas 7 and it is obvious all setting are compressing the file (and the final .mov file ends up being bigger than the original AVI, which is really confuses me!). The setting I am using are:
Project tab>video rendering quality:Best
Video tab>
frame size:NTSC DV (720x480)
Frame Rate:29.970 (NTSC)
field order:Lower field first
Pixel aspect ration:0.909
video format:Video
Compressed depth:15 bpp color (only selection available)
quality set at 100%
keyframe is checked and set to 30
I have also tried video format set to: DV/DVCPRO - NTSC which changes the Compressed Depth to 24 bpp color, with the same results.
The resulting file look compressed and have horizontal lines through them. I was reading other posts here which said they need to be deinterlaced for viewing on an LCD screen but would be fine on a TV. If this is true it begs the question, why don't AVI files played in media player have these same lines then??
Any help would be greatly appreciated.
Thanks much,
Duane
Duane Burleson is offline   Reply With Quote
Old January 24th, 2007, 05:31 AM   #2
Video tab>
video format:Video
quality set at 100%
Thanks much,
Duane
i haven't got access to my PC right now, so i can't double check this, but you should be able to select from a list of compression methods when you render to quick time. This list would contain things like sorenson, photo jpeg, animation and uncompressed!
interms of being bigger than you avi file this makes sense if your avi file is compressed. and if the avi is uncompressed then maybe you changed the dimensions of the clip, the frame rate, colour depth or even the sound settings.
the lines you see i would definitly expect to be there, it's a good sign if you want the clip to be interlaced (do you?). from your settings you describle it is clear that the video you are rendering will end up being interlaced. it is also true that you can not display an interlaced signal on an LCD monitor, which is why you see lines.
the reason they dont appear in media player is presumably because media player doesnt always display larger clips in it's full resolution. it skips lines therefore effectively deinterlacing what is displayed. something like that - either way, it's way player, not the clip.
Mauritius Seeger is offline   Reply
