What are the best project size for the HC1 - HD at DVinfo.net
Old January 21st, 2007, 08:11 PM   #1
With Vegas, what is the proper/best project size when capturing and editing HD footage ( I am using from the HC1 via Firewire) and will be editing the m2t footage.
David Delaney is offline   Reply With Quote
Old January 21st, 2007, 09:21 PM   #2
If you are editing in HDV with Vegas 7.0, select for your project properties:
HDV 1080-60i (1440x1080, 29.970 fps)
Capture will be throught he internal capture device.
Chris J. Barcellos
Old January 22nd, 2007, 03:22 PM   #3
Do most people just editing the m2t files? What is the benefit or disadvantage of the m2t?
Old January 22nd, 2007, 05:36 PM   #4
I edit the m2t files. I just capture, edit, do some compositing here and there (not heavy comping, mind you, that's for AE!) and then render out as 720p. Looks beautiful.
SB
Steven Bills is offline   Reply
