My saving quality? at DVinfo.net
Old January 17th, 2007, 02:44 PM   #1
My saving quality?
I have this problem all the time. When I try to save I don't know how to get the quality right? Its runs all slow and looks as if it has lines through it. Like TV scan lines, but I do not apply and effect like that. I don't know I know how to save properly.
EDIT: This is Vegas 6
Ryan Hand is offline   Reply With Quote
Old January 17th, 2007, 03:30 PM   #2
Those scan lines mean that your footage is interlaced, and if by save you mean render, then simply check the deinterlace checkbox in the render dialogue.
Steven Bills is offline   Reply With Quote
Old January 17th, 2007, 03:31 PM   #3
Jubal 28
OK, slow down there . . .
I assume you mean "render" and not "save" . . .
What are you trying to render?
How are you trying to render it? Format? Codec? Settings?
Be as detailed with all of that as you can.
Just general principles . . . if you're rendering as NTSC DV, you'll see the "scan lines" if you play the video on a computer, because that's the nature of interlaced video like NTSC. You'll also see it if you watch it on a progressive TV like an HDTV a lot of the time.
You won't see it on a standard TV, though.
Why it would be "slow," I'm not sure. Are you rendering uncompressed AVIs or MOVs?
David Jimerson is offline   Reply With Quote
Old January 17th, 2007, 05:27 PM   #4
I do mean render. I am actually trying to save or "render" a video my son made of a game called Call of Duty 2. He did all his editing but can't get the quality to render the way it shows in the preview. I have no Idea what, or how to change the settings. I'm just a dad trying to help his kid.
He says it "saved" and looked better in Windows Movie Maker and doesn't know why it doesn't work the same way.
Old January 17th, 2007, 08:55 PM   #5
When you "save" in Vegas, you're saving the project file (.veg file).
When you render, you're converting what's on the timeline to the desired output format (avi, mpg, wmv, mov, etc.).
What format did your son use when he saved it in Windows Movie Maker?
I'll ask David's question again ands add one of my own.
You said "my son made of a game called Call of Duty 2" but that doesn't tell us anything. What format was the original video? Was it a computer capture of some kind? Did he shoot it with a camcorder?
Quite honestly, the only way anyone can help you is with an answer to these questions.
Old January 18th, 2007, 07:14 AM   #6
I'm at work now, Ill check his settings when I get home and edit this post.
Old January 18th, 2007, 11:34 AM   #7
details
if you rendered to a 320x240 WMV file in vegas but he rendered in movie maker to a raw windows AVI (640x480) then of course his would look better.
we don't mean to sound harsh, but the proof and solution is all in the details.
jason
Jason Robinson is offline   Reply With Quote
Old January 18th, 2007, 11:51 AM   #8
details
Dupe post..... deleted
Old January 18th, 2007, 06:03 PM   #9
http://img253.imageshack.us/img253/7...titled1tl5.png
Those are the current settings. He uses in Windows Movie.
Old January 18th, 2007, 06:16 PM   #10
Thanks for the settings Ryan but you still haven't answered a few other questions.
Answer these and some answers will be forthcoming.
BTW, Vegas can easily match (or exceed, if desired) those settings.
Old January 19th, 2007, 01:57 PM   #11
He used and in-game record function. Then used a program called Fraps. It saves in AVI Format.
Old January 19th, 2007, 05:06 PM   #12
I'm not a gamer and have never used Fraps so I searched other Vegas forums.
I found a post where one poster was talking about the exact same issue you are (the thread was titled "My Video comes out blurry!!!") and, interestingly enough, the same game too :-)
The thread raised another question that hasn't been asked here yet and that is "what kind of movie do you want to make? Something to be played on a DVD or just a computer?
Here's some suggestions for you , depending on the route you want to take.
If it's for a DVD, render using Best mode in the Video rendering quality box. Also, use CBR at the max. of 8,000,000.
If it's for a computer, WMV is fine. Apparently Fraps allows you to record at much higher resolutions and frame rates than normal video. Make sure when you're rendering to match the original file properties as closely as possible. Vegsa allows you to tweak a lot of settings once you go into the Custom tabs area. For example, WMV can be rendered out at up to 1440 x 1080 and a frame rate of 59.94.
Finally, this message was in the Fraps Support FAQ.
"Pixelated/blocky capture with 84.xx Forceware drivers. Download fix in latest official nVidia driver (93.71)"
Old January 19th, 2007, 07:53 PM   #13
This is just for the internet. How can he edit customize the settings all he sees is description and render quality.
Old January 19th, 2007, 10:31 PM   #14
The steps are very similar to what I just gave David Delaney in the " 38 files - how to make a single DVD arch. 3 movie?" thread.
Since this is for the internet, it's a WMV he wants.
At render time, select Windows Media Video V9 (*.wmv) in the Template box. In the Save as type box, there are several different choices. Which one he wants is up to him.
After selecting the template, click Custom and then Video. There are more settings in here that can be tweaked as desired.
I've done very little encoding for the net so I'll leave the explanations of some of the options to folks that know more than me. He could also play around for awhile and see what he likes.
If he plans to play, I'd suggest saving each new group of settings as a new template (once again, see the other thread for how-to-do-this instructions). They can always be deleted afterwards.
I hope this helps you out.
Mike Kujbida is offline   Reply
