Popping Sound at DVinfo.net
Old January 17th, 2007, 09:40 AM   #1
Popping Sound
Hi Everyone,
I don't know if I should be posting this topic here or under XHA1. I use XHA1 and I just downloaded a clip into Vegas and I hear several popping sounds.
I tried different clips and they are all have popping sounds.
I connected the Camera to My TV and there is NO popping sound.
I am puzzeled as what I am not doing or what should be doing?
Please advise me. The camera is brand new.
I never had this problem with my consumer JVC camcorder.
Admin edite: replaced "poping" with "popping."
Matthew Amirkhani is offline   Reply With Quote
Old January 20th, 2007, 10:30 PM   #2
"Popping" is a pretty broad category of problems. Is there any way you can post a sample of the sound? Pops (Popes? Nah, I shouldn't go there) can be indicative of all kinds of different things. There's no way for us to tell what the sound you're hearing is without hearing it ourselves--unless you can describe it in a little more detail, maybe.
-->jarrod whaley.
www.oakstreetfilms.com
Jarrod Whaley is offline   Reply With Quote
Old January 20th, 2007, 10:40 PM   #3
I've noticed only once that Vegas can make a popping sound that is not there.
I had a music file that had a pop. I played the file out of vegas and the pop was not there.
Is the pop there in the file when it is not played in vegas?
Richard Zlamany is offline   Reply With Quote
Old January 21st, 2007, 12:37 AM   #4
This is a symptom of your computer. Lower the master volume on your PC and hopefully there will be no popping sounds.
Old January 22nd, 2007, 12:06 AM   #5
Hey Mathew. I just posted similar question above before I saw your question.
I am haveing the same problem.
Zack, I tried lowering the master volume on my pc and I dont think thats the problem. I can actually see the offending noises in the audio time line line. SOmething is causing them to be embedded in the audio after rendering.
Any Ideas?
Doc
Wayne Maxwell is offline   Reply
