Rendering for DVD Architect at DVinfo.net
Old January 16th, 2007, 04:42 PM   #1
Hello,
I am a new member and I would like to post my first question.
I've been searching and reading and sure you guys are all very Knowledgeable.
I would like to ask this question, after I finished editing in Vegas. in Reneder As field which template I need to choose?
My camera is Canon A1 and I use DV24f 16:9. Can I use the defult template or not?
Thank you
Matthew Amirkhani is offline   Reply With Quote
Old January 16th, 2007, 04:50 PM   #2
You'll render to the NTSC 23.976 Add Pulldown widescreen MPEG template. This will generate a DVD A compliant MPEG for creating your DVDs
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old January 16th, 2007, 05:03 PM   #3
Hi Douglas,
First of all thank you for quick answer,I just rendered the clip using
DVD Architect 24p widescreen video stream.But there is no sound.
What am I doing wrong?
Matthew
Old January 16th, 2007, 05:11 PM   #4
you also need to also render an AC3 audio file. There is a tool on the VASST site called "DVD Prep" that is free, that will assure your project renders the correct assets if you think it might help you.
Old January 16th, 2007, 06:45 PM   #5
Jubal 28
What you do is select a loop region to render. When you render your video, check "Render Loop Region Only" in the render dialog box.
Then, using the same loop region, do the same when you render your AC-3 file. This will ensure that the audio and the video match. Make sure you save the file with the same file name, and into the same folder, as the video.
Then, you drop/import your video into DVD Architect, DVDA will automatically bring in and match up the audio.
Assuming this is only stereo and not 5.1, you can actually render as either AC-3 or PCM (default .WAV). AC-3 takes up less space, but PCM is less compressed and can be higher quality. If you use PCM, be sure to make your DVD Architect project settings PCM.
David Jimerson is offline   Reply With Quote
Old January 16th, 2007, 10:50 PM   #6
Hi David,
Thank you so much for the link it was very helpful do you have any other trainings in regards to 24P? i.e slow motion etc...?
Thank
Matthew
Old January 17th, 2007, 12:41 PM   #7
Jubal 28
Just got some shooting done on some more. Probably will be released within the next month or so.
