Handwriting with Beziers? at DVinfo.net
Old November 18th, 2006, 03:29 AM   #1
I read somewhere the handwriting effect can be done in Vegas with the Bezier curves. Can someone tell me the details? Do I do a text first and next use the bezier to reveal the text like the way its written?
I tried figuring it out but just cant get it. Pls help!
Old November 18th, 2006, 06:44 AM   #2
Sponsor: JET DV
Yes. That's how you would do it.
Old November 26th, 2006, 02:05 AM   #3
Hi Edward, I tried it but the bezier needs a close loop. I cant figure out how can I make the words look like its written. Could u advise?
Old November 26th, 2006, 09:44 PM   #4
Sponsor: JET DV
Go ahead and close the bezier over a small area. Then, using keyframes, you have to make the mask larger an larger until everything has been revealed.
Old November 27th, 2006, 01:32 PM   #5
Here is a link to one of my videos produced, in Vegas, using the method as Ed describes:
http://www.advancedmedialab.com/poc/Signature.html
It's not great, but it shows what can be done.
If it doesn't start right away, press the reload button.
- Jesse
XL2 - Vegas - DVDA - Sound Forge - Acid Pro - Cubase SX 3
Jesse Redman is offline   Reply With Quote
Old November 28th, 2006, 01:37 PM   #6
wow
That does look like exactly what the posted requested.... and I admit to being interested in that effect as well.
jason
Jason Robinson is offline   Reply With Quote
Old November 29th, 2006, 09:54 AM   #7
Wow, nice job Jesse. It can be done! It does sound a little tedious though. I'll give it a try. Thanks Edward (as always..)
Old November 29th, 2006, 10:03 AM   #8
I'd love to see a vegas script for this.
Old November 30th, 2006, 03:17 PM   #9
Sean,
It is not as tedious as you might think. The first time takes longer for obvious reasons. The one you see in the link in my other post only took about an hour.
As a suggestion, you want to put in several points in your bezier mask. probably more than you think you need. The first letter is a special case but after it, you want to wind up with half of them below and before your image and the other half above, moving them to the front to reveal the image.
- Jesse
Old December 3rd, 2006, 08:25 AM   #10
ok, I'll try it out. Thanks!
Sean Seah is offline   Reply
