Newbie Question at DVinfo.net
Old October 27th, 2006, 07:18 AM   #1
Newbie Question
Hi there, I searched the forum for this answer and found something, but not sure. I am titling a 16:9 project and I wnat the titles on the bottom (black box) On my preview monitor it looks fine but on the Vegas 6 Preview box the titles are below the top saftey line and above the bottom.
Would someone mind tellling me the difference between the two lines, i.e.top line is 4:3 and bottom is 16:9?
Thank you in advance for your response.
Bradley D Barber is offline   Reply With Quote
Old October 27th, 2006, 09:49 AM   #2
Have you set the Vegas preview monitor to "simulate device aspect ratio"?
Right click on it to enable this option.
If your preview monitor is a video model (as opposed to a computer one), I'd trust it.
Old October 27th, 2006, 11:58 AM   #3
Jubal 28
What kind of project are you editing in? 4:3 or 16:9?
David Jimerson is offline   Reply With Quote
Old October 27th, 2006, 12:32 PM   #4
If it's an anamorphic 16:9 project, you can't put the subtitles in the letterboxed area because it's not really part of the image. And if it is 16:9 letterbox, you don't want to put your 16:9 into a 4:3 with a hard letterbox.
The two "safety" lines have nothing to do with aspect ratio. The inner box is the title safe area--you can safely put text inside that box. The outer one is the action-safe area--you anything outside that box may or may not be visible on a TV. Both 16:9 and 4:3 have these same safe areas, though their sizes are appropriate for the aspect ratio.
-->jarrod whaley.
www.oakstreetfilms.com
Jarrod Whaley is offline   Reply With Quote
Old November 7th, 2006, 04:24 PM   #5
It was shot in 16:9 and I am editing that way. I have rendered and previewed it on 4 different tv's and it all looks good! The project is for broadcast so I just want to cover all of my bases!
Thanks for all of your help!
Old November 7th, 2006, 06:37 PM   #6
Just to get it clear...
You shot and edited in 16:9 and you placed text in the 'black bars' above or below??
Puttin the wet stuff on the red stuff!
Terry Esslinger is offline   Reply With Quote
Old November 16th, 2006, 02:58 PM   #7
I shot in 16:9 and I edited in 16:9.
I placed the titles in the bottom blackness, below the image. It all seemed to work out well. I printed to tape and and previed that way as well. I was worried that below the first set of safety lines, would not allow my titles to be seen. However there is a set of saftey lines below my text.
Should I change my saftey settings? I am still practicing to customize my workspace. I have never changed any of these factory settings.
Thanks for any help!
Old November 16th, 2006, 03:16 PM   #8
If a 16:9 program is played back on a 16:9 Tv the image will fill the entire screen and the black bars (and whatever is in them) would not be visible.
(edit) This would be true for a 'true' 16:9 program not one shot with the pseudo 16:9 such as with a PD150
Old November 17th, 2006, 08:45 AM   #9
I shot the footage with a GL-2 in 16:9 mode. I previewed on good ole' regular tv. The text is in the lower box.
It has aired on television and all seems well. Trial by fire I guess! I would like to know if there are any settings I should change that would make sense, if I were to do this again.
Old November 17th, 2006, 02:33 PM   #10
I'm curious, have you seen it played back on a widescreen 16:9 TV set? Since I believe the GL2 does not have 16:9 chips and it does 'pseudo' 16:9 (just like the PD150) it would probably work as you are just placing the lettering in a 'cropped' area.
Old November 20th, 2006, 04:07 PM   #11
I did see it on a 16:9 screen. It looked fine. I did notice that when I burn it onto dvd it says it is a 4:3 project? I worked on it in 16:9 and probalby did the fit to screen "no letterbox" option was checked. However, by luck, it seems to work great! Thanks for your interest.
