The MSSQL$Sony_MEDIAMGR service does not exist
Hi,
I am trying to make the switch from P-Pro to Vegas. Right off the bat I'm having a few problems. After I installed the trial version of 7.0a I get the following message when I execute the program. "The MSSQL$Sony_MEDIAMGR service does not exist......" I did a search on this forum and found some information. I have not been able to solve the problem. Any advice would be appreciated. Thanks..
Tim Bickford |
Rextilleon
You need Microsoft Netframework 2.0 to make it work. You can download it here: http://www.microsoft.com/downloads/d...displaylang=en
Good luck, I swithced from Premiere and never looked back.
Red #97 |
Sponsor: JET DV
It installs as a separate step (automatically) after Vegas gets installed. You should have received notification of that additional step. If you did, look in the control panel. There should be a couple of entries there related to the media manager. If those are there, see if you can manually start the service. Beyond that, check with tech support.
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
Thanks for the help. I followed the direstions. + Also uninstalled everything and re-installed. I'm having the same problem.
"The MSSQL$SONY_MEDIAMGR service does not exist or the current account does not have enough privilege to manage it." Any other ideas... This is just not fun!
Tim Bickford |
#5 |
Sponsor: JET DV
Did you install Vegas as an Administrator?
#6 |
Edward-
Not sure??? Should I have? I look into it and re-post. Thanks... Tim
Tim Bickford |
#7 |
Sponsor: JET DV
Yes. You need to be an administrator to install the media manager services. Also be aware that you CAN run Vegas without the media manager as well (and it can be turned off in the preferences).
#8 |
Edward-
Thank you for the very fast responses. Yes... I am the admin + only user. Therefore the software was installed by the admin. What does the media manager do? How do I turn it off? Thanks again. I appreciate it! Tim
Tim Bickford |
#9 |
Sponsor: JET DV
If you want to turn it off, just go to Options - Preferences and low on the list is "Enable Media Manager".
The Media Manager is designed to "manage your media". If you have several buy-out libraries or footage you've taped yourself to be reused, it is frequently difficult to find the exact piece you need. With the media manager, you can add keys to help you quickly find the piece you need. I consider the Media Manager very useful when you have lots of reusable clips. I consider the Project Media useful for organizing the clips in a specific project. However, many like to use the Media Manager even for that. Do a search on "Media Manager" in this forum and you'll see other reports of installation errors plus other reports on how others have used it.
#10 |
Once again Edward. Thanks... I appreciate it. I've been using Premiere for 3 years. It's going to be a rough transition to Vegas.
Thanks... Tim
Tim Bickford |
#11 |
Sponsor: JET DV
Tim, to help get you started, you might want to read through my newsletters - especially the "Beginner's Corner" series beginning in the 4th issue. Just go to the newsletter archive section.
#12 |
Edward,
Thank you. I will do that now. Again you have been a big help. Tim
Tim Bickford |
#13 |
I have the same exact error after I installed. I think it happened after I updated. I am clueless as how to fix this.
#14 |
This is what most likely cause my problem. I found this on the Sony site.
0. Does your PC run any type of registry cleaner or maintenance tool such as PC Tools Registry Mechanic? We have observed that some of these tools delete critical Sony registry keys which causes ACID or Vegas to be unable to initialize the media manager. Sony recommends that these tools not be used. |
#15 |
Help
Hi,I installed Sony Vegas 7.0 on windows vista home premium 64-bit and after installation when I run the program system displays a dialog:
The MSSQL$SONY_MEDIAMGR service does not exist or the current account does not have enough privilege to manage it. I click OK and Sony Vegas start runnig,but when I drag a video in a timeline that displays only sound and video not...Can anybody help me? |
