External monitor at DVinfo.net
Old July 28th, 2006, 08:48 AM   #1
External monitor
I want to hook up a external moniter (Broadcast in future, for now TV) to my Vegas edit bay. I don't have a dv-cam around to use as a converter.
Is it possible to use the S-Video out of a cheap GPU?
(I own a onboard GPU (GMA950) now without S-Video or Composite out)
I have Sony Vegas 6.0 D
Julian Jansen is offline   Reply With Quote
Old July 28th, 2006, 09:42 AM   #2
Sponsor: JET DV
Go firewire -> convertor -> analog -> TV
Your other option in Vegas 6 is to use a secondary monitor if you have a two monitor setup. Going to a TV, I'd go via firewire.
Old July 28th, 2006, 09:48 AM   #3
Will this work, if I ad a extra GPu I'll have two vga out on that card and one on the onboard. Is it possible to have two monitors and via the third vga-out this convertor to tv?
http://www.colordrives.com/vga%20to%...0to%20tv-1.jpg
Old July 28th, 2006, 11:55 AM   #4
Sponsor: JET DV
For the most accurate image on the TV, stick with firewire. While other solutions *might* work, they may not work well or possibly give an incorrect image. If you want to play it safe, use firewire for SD external preview.
Old July 28th, 2006, 02:37 PM   #5
Ok, so S-Video isn't an option?
Old July 28th, 2006, 02:50 PM   #6
Sponsor: JET DV
Sure it is - assuming your convertor/camera has S-Video out.
Old July 28th, 2006, 03:20 PM   #7
I think he's referring to the s-video that is on his graphics card.
Kevin Richard is offline   Reply With Quote
Old July 28th, 2006, 03:23 PM   #8
The one on the video card
Old July 28th, 2006, 07:36 PM   #9
Sponsor: JET DV
Yes, I understand that. I'm saying he's better off ignoring the S-Vid connection on his video card and sticking with firewire. *IF* he gets it to work, there's no guarantee the colors will be accurate.
Old July 28th, 2006, 09:58 PM   #10
I figured that myself but wasn't sure... I think his problem was that no one gave him a clear and concise "No" ... now they have ;)
Old July 29th, 2006, 04:58 AM   #11
Thanks! Going to figure it out...
Old July 29th, 2006, 06:19 PM   #12
Here's what I did, using a Sharp consumer camera:
* Connect Firewire from PC to Camcorder.
* Connect S-Video from Camcorder to TV
* Connect AC power to Camcorder (rather than battery power)
* Turn on TV
* Turn Camcorder on in VCR-mode (not camera mode)
* Press record (but leave it paused)
* Set up Vegas to output its signal to 1394.
Works great!
Jon Fairhurst
Old July 29th, 2006, 10:23 PM   #13
Sponsor: JET DV
You don't need the "press record (but leave it paused)" step. It should pass the signal just fine WITHOUT a tape even being in the camera!
Old July 30th, 2006, 12:29 AM   #14
Hmm, He actually might... I have a sharp and it doesn't do pass through out but it does have pass through in... I can go vcr > cam > firewire > PC but I can't go PC > cam > monitor... BUT I didn't try rec/pause mode... that might help.... I'll give it a test when I get back home and report back... I would be rather pleased!
Old July 30th, 2006, 01:12 AM   #15
When I follow that steps , without te record/pause step , it doesn't work for me...
Vegas:
Hot pluggable device
Device unavailable
Please help me!
Cam: Sony DCR-TRV120E PAL
