Making DVDs seems impossible from PC to Mac - Page 2 at DVinfo.net
Old May 9th, 2006, 09:03 AM   #16
One of my friends figured out how to burn it. However, I have a project that is too big to fit onto one 4.7gb DVD. How do I cut the .mpg (mpeg2...which will be demuxed into .m2v with MPEG Streamclip later) file in half, as well as my .ac3 file in half exactly where I cut the video, so I can burn onto two separate DVDs? Or alternatively, how do I compress the video (6.5gb) down to around 4gb, although I realize there will be a significant quality hit?
Alex Thames is offline   Reply With Quote
Old May 9th, 2006, 11:00 AM   #17
Dvda
If you are using DVD Architect, when you render the final version you have the option of "fitting to disc." This changes the bitrate encoding of the MPEG2 stream to allow for a smaller file size. Try this option.
jason
Jason Robinson is offline   Reply With Quote
Old May 9th, 2006, 02:36 PM   #18
Nope, I don't use DVD Architect. Like I said, I am using DVD Studio Pro 4 right now.
Old May 9th, 2006, 04:09 PM   #19
>>>I used a PC and Sony Vegas 6.0d to edit my project.<<<
then you should be able to encode an mpeg2/ac3 file into whatever size you want, based on the original footage that you edited... there are some great bitrate calculators over at videohelp.com, that you can use to tell the vegas mpeg encoder what bitrate to use.
failing that, check out www.womble.com, for the mpeg editing software that'll let you cut your 6.5gb file in half, ac3 and all... it will also demux the file for you...30-day free trial on it?
Dan Euritt is offline   Reply
