#16 | |
#17 |
I don't have the source - it is from MS Flight Simulator - vehicle against a blue sky. I only have the Mpg from that. Not sure how to strip it out any other way than keying.
I tried what DSE suggested but I'm still ending up with a little fringe around the ship. This - after using a garbage matte. I'm still playing around with it though. I will post again if I can figure out the settings properly to blur that last bit out. tks.
Phil Hamilton hamiltonp@sbcglobal.net Dallas, Texas " I'm shocked, shocked to find that gambling is going on in here! ..." |
#18 |
Ok, that makes much more sense then. Sorry, I just thought you were trying to do something the extremely hard way.
To be honest, I've not had the best success with Vegas' keying. I LOVE Vegas, and most of its tools are just great. But when it comes to keying I stick with After Effects. Much more control. But, this is a Vegas thread and we want to keep it Vegas oriented. So long live Vegas! |
#19 | |
#20 |
Shawn, that file is almost impossible to perfectly key, not only because it's DV originated, but because it's a 320 x 240 wmv, making it even more compressed, hence the greater difficulty. If you work with it closely, you shouldn't find the hairs to be difficult as much as trying to avoid the earring that is just about the same color. If you use just a tad of secondary color correction to even out the green, looking at the mask as you do so, you'll significantly help that smooth out.
BTW, Louise is my mom so be nice with that clip. ;-)
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#21 |
DSE - Well I am unable to get the jiggedy-jaggies and blue noise off the Jupiter 2 ship on my keying. I think this is because the resolution of the origianl clip was captured in MSFS with FRAPS and therefore the resolution is not all that great - giving the blue background and extra foot hold I believe on the unclean and not very smooth edges.
The masking example I am going to play with some more but I could not tell any difference in doing that vs. just keying the regular shot. I must be doing something wrong - adding the blur IMO should soften the edges some but using the small amounts as suggested in your VASST tutorial don't do the trick. Making the blur higher really jacks with the entire image. Any other thoughts on this?
#22 |
if you wanna post a still, I 'll take a crack at it. If you can't get it up today, I won't be able to; we leave for NAB in the morning.
#23 |
Okay Spot - here you go:
http://www.geocities.com/hamiltonp@s...t/jupiter2.jpg I think it is just an image that is problematic from the get-go. Tks.
#24 |
If the jpeg is representative of your originating image (easier to see in png than jpg) then the problem is the codec with which the original image was captured. It's a pretty nasty compression, that's for sure. Easy to key, but you'd need a tight garbage matte, and even that won't cut the forward spill without affecting the landing gear of the ship.
I'd try for a higher quality source.
#25 |
DSE - thanks for looking. I suspected as much. Unfortunately I don't have a better source. For the distance shots it actually looks ok. It just looks bad on the close up. I will post the clip I did as soon as I finish tweaking it.
#26 |
keyed sample....
my.omsdal.com/thesky.wmv
Check this out - let me know how the spaceship looks...
#27 |
hey thats preety cool good job. id say a little too on the generic spaceship side but who cares.
#28 | |
But the point is that even with poor original spaceship footage - the ship landing in the park across from my house doesn't look half bad - all done in Vegas. Would'nt past muster for a pro-job but for a hobbyist like me it's good. I learned a lot doing this and I appreciate everyone's help and ideas.
#29 |
Phil,
I think that's pretty good! Especially for fan film type of material. And having done it all in Vegas?! You've got my respect. Like you said, it wouldn't work for a pro job, but just as hobby stuff this is better than most stuff that's out there. Everyone and their dog tries to do sci-fi stuff (mostly Star Wars) and a lot of it ends up looking like junk. It looked quite nice. I could nit-pick it but I think it would be pointless. Well done, and thank you for posting it. |
