Vegas Video discussions from 2003 - Page 77 at DVinfo.net
Old September 23rd, 2003, 05:33 PM   #1141
Sponsor: JET DV
Even if you got it to work, the colors wouldn't be accurate. Preview via firewire to see exactly what you will be sending to tape.
Edward Troxel is offline
Old September 23rd, 2003, 07:52 PM   #1142
Thanks for the advice, but i di not seems to find the tool button to allow me to do a freeform maskout for vegas like photoshop.
Wondering if vegas has such function at all?
Yow Siang is offline
Old September 23rd, 2003, 08:33 PM   #1143
Space Hipster
Suppposedly, the Parhelia does calibrate it's NTSC output (has full controls), but if it's not an option, I will stick with the firewire output.
Thanks for the info.
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline
Old September 24th, 2003, 12:52 AM   #1144
If you want people to see the commercial, do not put much information at the bottom. Put a web address, add shadow and let it stand still. That looks professional. The postal address and whatever will be at the web address anyway, and if they don't pick up on that, they won't pick up on your postal address and whatnot.
Tor Salomonsen is offline
Old September 24th, 2003, 04:33 AM   #1145
Am I The Only One Who Can't Import Into Vegas?
I've read the other threads. I have Vegas 4.0d (not the +DVD version). I've renamed the .m2t files from this site to .mpg and
was able to play in Media Player 9 but get the following message
when I try to import to Vegas: "An error occured while opening one or more files, the file format plugin for the specified file was not properly initialized." Any thoughts would be appreciated.
Dave Largent is offline
Old September 24th, 2003, 05:00 AM   #1146
trix
did you do a conversion from transport stream to program stream (demuxing) on the m2t files first?
Do this using the HDTVtoMPEG2 app v1.09
VEGAS:
have you download the mailconcept HD codec?
John Eriksson is offline
Old September 24th, 2003, 07:39 AM   #1147
Sponsor: JET DV
You have to do the masking by using other tools such as the secondary color correction tool. This will allow you to create a mask based on a color.
Old September 24th, 2003, 08:07 AM   #1148
John,
Thanks. No, I haven't done either of these. Are both these required prior to editing in Vegas?
If you could describe the workflow (for example "first do this,
second do this", etc.) this would be helpful.
At any rate, do you know where to get the Mainconcept HD codec?
Dave
Old September 24th, 2003, 08:22 AM   #1149
HDV Cinema
I've been told Vegas v4 reads TS files directly.
Steve Mullen is offline
Old September 24th, 2003, 08:50 AM   #1150
thanx for the response,
i tried doing it to dv avi, however it came up with the same unknown error.
its not an urgent or extremely important project, however it eventually worked and aretefacts were actualy very minimal, which surprised me...
usually i work in raw formats as much as posible, but this jsut baffled the hell out of me...
i thought it was heat also.. but the system was running extrmely cool consideirng the environmental temps
Peter Jefferson is offline
Old September 24th, 2003, 11:58 AM   #1151
Barry Wan Kenobi
Vegas 4 does read the transport streams directly. You have to have registered the program and it should then download the mainconcept codec, and after that you should be able to directly edit the transport streams.
Barry Green is offline
Old September 24th, 2003, 01:34 PM   #1152
color space
Does Vegas4 use YUV or RGB?
thanks,
John
John Hartney is offline
Old September 24th, 2003, 01:45 PM   #1153
Sponsor: JET DV
My understanding is that it is RGB.
Old September 24th, 2003, 06:35 PM   #1154
subject masking
I have seen many videos with just certain human with colours and the rest are all b/w. is there anyway to do that with vegas?
yowsiang
Old September 24th, 2003, 07:19 PM   #1155
Not specifically. You can use the cookie cutter fx for a rough effect, using keyframes. I'm trying a demo of Adobe After Effects using the "vector paint" tool to make a moving mask. The process is called "rotoscoping" and there's apparently no easy war to accomplish it. Basically, you have to "paint" virtually every frame to achieve a satisfactory effect.
George Brackett III is offline
