Vegas Video discussions from 2003 - Page 71 at DVinfo.net
Old September 11th, 2003, 10:18 PM   #1051
Vegas titles have artifacts.
It's when I put white text on a pure black background.
It's no biggie, but I was wondering if there's a quick fix to this.
Gerald Lee is offline
Old September 11th, 2003, 10:41 PM   #1052
Gerald,
Can you provide some more details about what you are doing and seeing? Are you rendering to a particular codec (DV, WMV, etc.)? If so, at what resolution? Are the titles moving?
The DV codec can sometimes show a few pixels being the wrong color since color is only sampled every 4 pixels. To check to see if this is what you are seeing, try rendering to MPEG2 or WMV.
Randall
Randall Campbell is offline
Old September 12th, 2003, 02:41 AM   #1053
I think there is an option to "open copy in soundforge"
Jake McMurray is offline
Old September 12th, 2003, 11:01 AM   #1054
Rob Lohman: How do you de-interlace each clip on the timeline? When you set the preferences, don't the clips automatically get de-interlaced as soon as you pop them on the time line?
Hugh DiMauro is offline
Old September 12th, 2003, 01:36 PM   #1055
RED Code Chef
I don't know, Hugh. I never de-interlaced anything in Vegas because
I shoot progressive. But if you add something to the timeline
right-click on the event and make sure the it is interpreted as
progressive (none) instead of lower field first. Also make sure
your project is progressive and when you output you set it to
progressive as well (default is interlaced EVEN with a progressive
project!!!!)
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old September 12th, 2003, 07:35 PM   #1056
Thanks guys. I found that the Graphic EQ did the best job of removing the hiss.
Dylan Couper is offline
Old September 12th, 2003, 10:30 PM   #1057
Veags DVD Tutorial
I'm thinking about buying the 4 disc DVD training video on vegas 4.0 and wanted to ask you guys if you know about the video. Like is he on the computer doing samples or screen shots. I have heard alot about and have done my research but have not found out if he is on a computer or just talking.
Jamison Olivieri is offline
Old September 13th, 2003, 12:01 AM   #1058
The broadcast safe filters are under Video FX and are called "Broadcast Colors". They allow you to set up clipping ranges for both Luma and Chroma individually, and with both combined. You can also add in setup.
Sean R Allen is offline
Old September 13th, 2003, 04:03 PM   #1059
To remove steady noise, equalizing will go a long way. I once removed the sound of a working electric dishwasher from a shot where the person talking was less than 2 metres from the dishwasher in a small kitchen. But then I used the Sonic Foundry Noise Reduction. I actually bought it for that shot, because equalization got me nowhere. The manual has a section on how to use it with Vegas. And with Sound Forge, if you have that. It's magic.
Tor Salomonsen is offline
Old September 14th, 2003, 08:20 AM   #1060
Jake is right; choose "open copy in Sound Forge" save as many altered copies as you like and then choose which take you want in Vegas.
Randy
G. Randy Brown is offline
Old September 14th, 2003, 07:01 PM   #1061
XM2 and vegas 4? Grazie you have both right?
Well I´m getting tired of the old Premier I have here.
and want to try Vegas as it seems to fit more my needs.
But the Sonicfoundry site doesn´t mention the Canon XM2 in their Hardware Compatibility and before downloading 40 megs on a modem I would like to know If I can use it with my XM2 for capturing and previewing in an external monitor and print to video and all that kind of stuff you do when do not have a deck...
Any problems with these???
Thanx
Messenger Boy : The Thessalonian you're fighting, he's the biggest man I've ever seen. I wouldn't want to fight him.
Achilles : That is why no one will remember your name.
Federico Dib is offline
Old September 14th, 2003, 08:58 PM   #1062
Sponsor: JET DV
Works fine with my XL-1. Shouldn't be a problem with the GL2/XM2 either.
Edward Troxel is offline
Old September 15th, 2003, 06:00 AM   #1063
Vegas4 and XM2 here! Works like a dream! :)
Cosmin Rotaru
Cosmin Rotaru is offline
Old September 15th, 2003, 07:51 AM   #1064
All right... Thanxs..
Old September 15th, 2003, 11:02 AM   #1065
duplicating sound channel
I recorded some audio in only one channel. I want to make it stereo. How do I duplicate that single channel into both channels?
