Vegas Video discussions from 2003 - Page 68 at DVinfo.net
Old September 10th, 2003, 02:34 AM   #1006
RED Code Chef
Perhaps this thread and this thread
might be of some use. Although you've probably already seen them.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old September 10th, 2003, 02:46 AM   #1007
RED Code Chef
The reason Nero doesnt like Architect files is that Architect and nero run 2 different disc file systems
If that would be the case then your disc will never ever play on
any settop DVD player. DVD's require to be in UDF file system
with certain sector sizes. It is even pre-determined on what
sector EACH FILE starts.
Old September 10th, 2003, 04:58 AM   #1008
Maybe i wasn't too accurate with my meaning Rob
Some authoring apps keep the file system as a straightforward VOB splits which are stored in the Video-TS folder. (DVD-A style and most commercially available dvd's)
Others keep the audio in the Audio-TS folder while splitting the m2v file and using a different index system (IFO-edit style)
From memory (i haven't done a dvd rip for ages) this is the older file system I THINK... vcdhelp would have more info on this though...
DVD-A keeps it as simple as possible being the first type mentioned.
My actual comment was innacurate i'm afraid, it's not the file system in general but the indexing of the files once prepared in DVDarchitect.
My mistake and we've gone completely off topic.. sorry!!
Peter Jefferson is offline
Old September 10th, 2003, 07:55 AM   #1009
Thanks all
Thanks all!! Works perfectly!
jinghong
Jinghong Chua is offline
Old September 10th, 2003, 08:05 AM   #1010
Images: 32
There probably are small errors but so far I can't see any differences. I'll re-post if I run into any issues with compositing the effects in Vegas.
Thankfully, muzzle shots, light sabers, plasma bolts, and magical incantations don't have to be pixel perfect, just close enough.
I'm guessing?? that compositing the effects with the original video in Vegas saves me one generation of rendering?
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline
Old September 10th, 2003, 09:48 AM   #1011
RED Code Chef
I must say that I've never ever seen the AUDIO_TS directory
being used on any of my commercial DVD's I have here (over
a 100). Only VIDEO_TS is used with VOB's, IFO's and backups
of IFO's.
Are you perhaps referring to a flat file structure with VOB & IFO
files or an actual disc image?
According to the DVD-FAQ
since the DVD-Audio specification includes new formats and features, with content stored in a separate "DVD-Audio zone" on the disc (the AUDIO_TS directory)
This says it is for DVD-Audio discs and not for storage of Audio
elements that are needed for a DVD-Video
I'm so sure we've gone off-topic since we are trying to discuss
why the DVD-Architect way might be different and thus cause
"problems" with other applications.
Old September 10th, 2003, 10:00 AM   #1012
RED Code Chef
If you use a lossy compression format inbetween normally, then
yes, you've saved a generation. If you use a lossless codec or
uncompressed it is the same.
Old September 10th, 2003, 10:17 AM   #1013
well, its been a while since i delved into the IFOEdit side if things now that DVD Authoring has taken off and its all done with dedicated authoring apps...
and i agree we have gone off topic, but I TOTALLY agree with your comments about
"I'm so sure we've gone off-topic since we are trying to discuss
"problems" with other applications."
I guess its up to SoFo to fix....
heres hoping
Old September 10th, 2003, 10:30 AM   #1014
I won't be messing around with my video anytime soon, my computer took a dump yesterday!
I know this is a bit off topic, but maybe you guys have experienced something like this.
Earlier this year I was on the computer and the screen went black. The monitor posted a message like-"check pc and connection. monitor working properly" I turned the computer off, checked all of my connections, turned the computer back on-nothing. the computer was getting power, it lights up, fan runs, but when I turn it on-no beep, blank monitor. It was dead for 2 or 3 days, then I turned it on and it beeped, fired up and worked fine.
It worked great for a couple months. Then all of a sudden, screen went blank. same thing. This time I stuck my hard drives in my daughters computer and they were fine. I hooked my daughters computer up to my monitor and it worked fine. So I figured it has to be the mother board or processor right? The second time it was dead for 5 or 6 days, then one day it started fine and worked ever since. that was the first week of june, so it's been just over two months and the darn thing did it again!
Sounds like it's time for a new computer huh?
Oh, it's a Mitsuba? 1 ghz Amd Athlon.
I guess I could just replace the motherboard or processor if I knew exactly what it was.
Adam VanScoyoc is offline
Old September 10th, 2003, 10:38 AM   #1015
RED Code Chef
I was wondering the same so I tested this. At first I just thought
you were able to copy a single column or line. But if you click the
block between 'Track' and '1' it selects the whole sheet for you.
Hit CTRL+C (or right-click and choose copy) and then you can paste
that into a text-editor or better yet in a spreadsheet program
like Mirosoft Excel. Worked like a charm!
It even pasted it correctly on each column and row so that you
can really use it or export it out as something like a comma
seperated file.
Neat.
Old September 10th, 2003, 10:46 AM   #1016
From what I understand, there are two ways to use it.
One way is to just select one of the presets from the pull down menu (i.e. 'default for fast computers'). You right click the audio clip, select apply non-realtime FX, pick the noise reduction plug in, and then you get the setup window. Choose one of the presets and apply it to the audio. You can preview it with the checkbox on/off and the mini play button in the upper corner.
The other way to use it is two pass; you 'analyze' part of the clip (I think there are buttons/sliders/etc for doing this) and then the noise reduction may be more efficient at removing that specific noise (you analyze part of the clip where the noise is isolated, i.e. a 'silent' part) when you apply the effect. This option is probably better if your noise is strange, i.e. not just tape/electrical hiss.
I think when you apply the non-realtime effect, it makes a copy of the audio track and applies the effect to it, and replaces the original audio on the timeline with the new clip.
If you apply the effect by opening the audio in soundforge, you may be altering the original audio track, which I don't recommend (because it makes it difficult to undo processing if you don't like it.
Bruce A. Christenson is offline
Old September 10th, 2003, 04:11 PM   #1017
Images: 32
Thanks for the tip!
Just to check - we have to use CTRL+C to copy the data, right? We can't use a right-click or the Edit menu?
Old September 10th, 2003, 04:46 PM   #1018
Images: 32
Vegas 4 startup when camcorder is turned on? Win XP Pro
Right now, Vegas 3.0 comes up.
Old September 10th, 2003, 05:16 PM   #1019
Images: 32
Deinterlace method? Questions
1. Is this correct?
Blend makes video choppier but there is no ghosting
Interpolate makes the video smoother but ghosting will occur
2. Do you use the de-interlacer in Vegas or something else?
Do you recommend using VirtualDub over Vegas?
3. Should I de-interlace before or after editing in Vegas?
Old September 10th, 2003, 06:59 PM   #1020
thanks guys .. this is exactly the info I was looking for .. vegas looks more and more like a real contender :)
PD150
Carlos Rego is offline
