Vegas Video discussions from 2003 - Page 62 at DVinfo.net
Old September 2nd, 2003, 07:38 AM   #916
Where is Boris for Vegas???
ggrrr.....
yes im still waiting...
hey does anyone here use graffiti? apparently it does vector texts... hmm...
any thoughts on what Boris for vegas will have??
Peter Jefferson is offline
Old September 2nd, 2003, 11:16 AM   #917
uhhh... it's being packaged with Avid XpressDV?
Richard Alvarez is offline
Old September 2nd, 2003, 11:46 AM   #918
Sponsor: JET DV
I read in another forum that they pushed the release date back inorder to make it more compatible with all the new NLE's that exploded onto the scene.
Edward Troxel is offline
Old September 2nd, 2003, 12:28 PM   #919
BAHH HUMBUG!!!
well SoFo... have a look at the "what i wanna see in vegas" thread and get cracking!!
Old September 3rd, 2003, 11:44 AM   #920
Audio dropouts while printing to tape
Has anyone else had this problem?
While printing to tape the music will stop about half way thru the clip. I played the clip back on the computer and everything seems to be just fine. I've tried a number of things and I give up. Tried playing with sample rates but no luck.
The video is very smooth, looks terrific and no frames are dropped. It's just the darn audio.
I wanted to note that I am printing to a DVX100 and using 24p 2-3-3-2 pull down.
Best Regards,
Mark T. Monciardini
Riverlight Studios
www.riverlightstudios.com
DVX100/Final Cut Pro 4/Mac G5 Dual 1.8
Mark Monciardini is offline
Old September 3rd, 2003, 12:21 PM   #921
hmm..
this usually happens on the PC end..
i know some AVI files are huge and wnblows wont allow a defrag, but is there any way to clean up your HD ?
what kind is it?
usually drives with low cache experience this
Old September 3rd, 2003, 12:29 PM   #922
Hi Peter. After reading on the Sonic Foundry boards it seems to be a major problem.
I have a custom built PC with a SCSI SeaGate 15,000 RPM drive 18 gig.
I'll try and defrag and see if that helps. Thanks.
Best Regards,
Mark T. Monciardini
Riverlight Studios
Old September 3rd, 2003, 02:33 PM   #923
Edit log
I'm just wondering if from Vegas I can export a spreadsheet of the clips in the timeline and when they start/end and when cuts/effects/transitions take place. I am not at my computer so I cannot see if there is anything I can do. But I know that there must be a way to do it. Or I think there might be a script that we could write.
Rob
Robert Poulton is offline
Old September 3rd, 2003, 02:47 PM   #924
Sponsor: JET DV
Take a look at the Edit Details screen. You can copy and paste the information from that screen.
Old September 3rd, 2003, 04:02 PM   #925
Thanks Edward. I'll do that once I get home in 20min. hehe off to editing.
Rob
Old September 4th, 2003, 04:55 AM   #926
Will vegas 4 handle new HD format
I will be getting V4 soon now and was reading the tech stuff for the new canon - sony - JVC - Sharp format. Sonic foundry's knowledge base search feature came up with the following info on supporting High Definition.
Editing
High Definition editing and output
Vegas 4.0 supports HD editing and rendering, including output to 1080/60i, 1080/30p, 1080/24p, 720/60p, 720/30p, and 720/24p. Output high definition video to .AVI, .MOV, MPEG-2, Windows Media 9 Series, RealVideo 9, .PNG and .JPEG sequences. Work with project sizes up to 2048x2048.
Will the 25p format planned by the canon - sony deal throw a curve to Vegas 4? It looked like they had planned on 24p.
Don Parrish is offline
Old September 4th, 2003, 05:04 AM   #927
well, the drive isnt lacking thats for sure, even a defrag wont do much to help it, but you never know.
its a common problem, but as i dont print to tape, i really dont have any more ideas... :(
Old September 4th, 2003, 07:08 AM   #928
Sponsor: JET DV
Vegas is pretty well format agnostic. However, it cannot capture or print some formats. For example, it can EDIT HD, it just can't capture it or put it back to tape. With 24p, it can capture, edit, and print. I don't know about the new canon format but isn't 25p simply PAL?
Old September 4th, 2003, 08:23 AM   #929
Mark I don't know if this has anything to do with your problem but SoFo recommends your final output to be standard 2-3 pulldown. So if you shoot in 24pAdvanced mode (w/ 2-3-3-2 pulldown) you should capture using the 24p template (that removes pulldown) do all prerenders with 2-3-3-2 but for final output it should be changed to 2-3.
Check out more info here:
http://www.sonicfoundry.com/forums/S...ssageID=175137
Hope this helps, though I'm skeptical this would affect your audio cutting out during export. Anything is worth a try!
Glen Elliott is offline
Old September 4th, 2003, 08:25 AM   #930
Yeah the PAL Canon GL-2 and XL-1s frame mode is 25p?!
