Vegas Video discussions from 2003 - Page 32 at DVinfo.net
Old June 24th, 2003, 10:23 AM   #466
Vegas will read most still image formats you can throw at it. And you can easily change format once you've captured your frame (in an image editor).
I've seen a perfectly reasonable explaination from (I think) one of SoFo's Vegas team, but it's been several months, and I can't remember what it was, nor in what context it came up.
Tor Salomonsen is offline
Old June 24th, 2003, 10:45 AM   #467
I've checked a little: .png is the best. In the words of SonicEPM: .png will result in a high quality still, with alpha channel.
Jpg is good for some things because it has a trade-off between size and quality. Tiff may be good for archiving, but Vegas will have to use Quicktime to decode it. And it does not have alpha channel in any way practical. Targa wasn't metioned in the little search I did.
Old June 24th, 2003, 03:02 PM   #468
thx for the info. Yah I just don't understand why they wouldn't make it easy to export still frames and save to all the formats out there. It is my only complaint with vegas. Since most of my other apps will allow for me to do everything I want.
Rob:D
Robert Poulton is offline
Old June 24th, 2003, 03:16 PM   #469
captured .jpg size in V V 3
Can anyone please tell me where to change the size? 320x240 seems to be the default, and i can't find my way around to change it to 640x480. Thanks!
Hey Tom, sorry i lost touch.. hope y'all are doing well.. hi to Kelly:)
Nancy
Nancy Hussey is offline
Old June 24th, 2003, 04:56 PM   #470
Sponsor: JET DV
Right-click the preview screen and pick "Display at project size"
Now take the snapshot.
Edward Troxel is offline
Old June 24th, 2003, 07:50 PM   #471
Cool. I'll give it a try.
Dan Measel is offline
Old June 25th, 2003, 07:10 AM   #472
Thank you so much, Edward..
I'm still having trouble getting clear frame grabs
(surfing pics.. like this one, for example)
http://www.follysurfcam.com/june03rc/redlb.jpg
even tho i use the movie mode.... I finally got a nice tripod, am using GL-2 & both Studio 7 & V V 3... must be ME!
thx
nancy
Old June 25th, 2003, 08:14 AM   #473
explain what you want in more detail, and I'll try and write a script to do it for you
Eric Richmond is offline
Old June 25th, 2003, 10:28 AM   #474
Sponsor: JET DV
Yes, getting GOOD snapshots is really a multi step process. It's MUCH easier in Vegas 4 as there are scripts available to do it all for you.
Here are the basics:
1. Right-click the preview to choose "Display at Project Size" will get you the full size.
2. Change "Preview" to "Best" on the preview screen.
3. Under File-Properties, change the project type to "Progressive" (or non-interlaced)
In Vegas 3, I usually simply did the first two and then de-interlaced in PhotoShop.
Look at the newsletters at http://www.jetdv.com/tts to find more information about snapshots (issue #5 to be precise).
Old June 25th, 2003, 11:37 AM   #475
oh. All I was questioning is why they didn't allow us to export into still frames with the option of using any format. I mainly use targa and tiff for the 3d and other video work. So I just thought it was akward for them not to offer these and other formats as options. No biggie. png should do fine. Anything is better than jpg.
Rob:D
Old June 25th, 2003, 03:28 PM   #476
hey thanks for the info, edward.. am reading that now..
my nephew works for sonic foundry & gave me vv3, think its time to beg for 4! it looks easy on 4...
nancy
ps. its just a good thing that surfers aren't too picky about their shots!
Old June 26th, 2003, 07:43 PM   #477
_redone_
vegas video 4
this question was originally intended for bill ravens in another post, yet if anyone else know then horay!
im working in vegas video 4 to take NTSC down to PAL...I
rendered as a PAL DV template and got very interpolated
results....Is there another method in doing this? or is there a certain method i shoudl take before output?
Adam Lawrence
eatdrink Media
Las Vegas NV
www.eatdrinkmedia.com
Adam Lawrence is offline
Old June 27th, 2003, 02:45 PM   #478
Hawaiian Shirt Mogul
you might try -
in your project properties ( vegas - file - properties) change the deinterlace method to BLEND .. then render out to PAL - should be little smoother
Don Donatello is offline
Old June 27th, 2003, 02:56 PM   #479
Slash Rules!
Yarrrrgh! Stupid Vegas 4 pan and crop tool!
Okay, let's say I want to size the video to make a box that fills half the screen. I want to keep it the entire 4:3 frame. When I use the Vegas 4 pan and crop tool to do this, for some reason, if I try to move the box around, it starts to get cut off, and disappear. I can only keep it on one side of the screen, instead of being able to move it where I want. When I try to go to the other side, it starts to crop until it disappears. What am I doing wrong? I want to be able to move it anywhere. I've tried playing with the "lock aspect ratio", "move freely", and "size about center" buttons, and still it does this. I can't use the 3d plugin pac because I recently found out that it acts on both fields of video and once, creating a "frame mode" look, and this footage is 60i and needs to remain so.
Josh Bass is offline
Old June 27th, 2003, 03:29 PM   #480
you might try setting your shutter speed to 1/500 or faster for good still photo's but it might be too much for video use ?? perhaps you can find a happy medium ( shuttter speed) somwhere that works good for video and stills
