Vegas Video discussions from 2003 - Page 30 at DVinfo.net
Old June 23rd, 2003, 04:48 AM   #436
Open the clip's properties. There's a menu for Method, where you select Change pitch, preserve lenght.
Tor Salomonsen is offline
Old June 23rd, 2003, 07:00 AM   #437
Vegas Acedemic Version
Did a search on this subject, didn't seem to find the answer.
Is the Acedemic Version the same as the regular retail version? I could get the Student copy, but what the whole shootin' match.
Any thoughts?
Jeff Troiano
Jeff Troiano is offline
Old June 23rd, 2003, 07:07 AM   #438
It's the same.
But on any rendered project a small red L is displayed in the corner. (joke!)
Old June 23rd, 2003, 07:13 AM   #439
Try a search on "Vegas Academic Version"! :-)
Nigel Moore is offline
Old June 23rd, 2003, 07:27 AM   #440
In response to the original question:
You can select a segment of the timeline (mute any track you don't want included) and render it, having selected render loop area only. Then you'll be able to see what that sequence will look like in the final render.
Old June 23rd, 2003, 07:29 AM   #441
About deleting time, please read up on Ripple Edit. I'm not sure I fully understand it myself. But I know the answer is there.
Old June 23rd, 2003, 08:26 AM   #442
High School Student
You can also right click the audio track and "apply non-realtime effects events" (or something like that) and you can do a whole bunch of stuff to the audio.
Alex Knappenberger is offline
Old June 23rd, 2003, 08:40 AM   #443
Sponsor: JET DV
<<<-- Originally posted by Glen Elliott : Wont that change the "lenght" that the audio plays. Can't you change the pitch without altering the length of the clip's audio? -->>>
Yes, CTRL-Drag changes the length of the event. The original post mentioned wanting it to play faster.
And, yes, you can also change the pitch without changing the length. There are many options related to this when right-clicking the audio clip and choosing Properties.
Edward Troxel is offline
Old June 23rd, 2003, 10:48 AM   #444
this is where sonic foundry shine...
audio...
the best thing about it is that u can open the audio in soundforge for refined audio work in total sync to the video...
Peter Jefferson is offline
Old June 23rd, 2003, 11:08 AM   #445
Are you using Type 1 or Type 2 for the AVI file ?
I'm not sure if there is any limitation for one of it.
Dany
Dany Nativel is offline
Old June 23rd, 2003, 12:06 PM   #446
I don't think Premier can specify Type 1 or Type 2.
The odd thing, again, is that the files are fine when viewed by Premier or Media Player, but Vegas won't read anything beyond 4 GB, and the reason that I know this is that the file is about 5 GB and the part that cuts off is about 4/5 of the way through.
I guess I'll just have to split the files up.
Peter Moore is offline
Old June 23rd, 2003, 12:37 PM   #447
If you use ScenAnalyzer you can capture (and also export) but also specify Type 1 or Type 2 file (+ a lot of additionnal features).
But in your case it looks like the problem is elsewhere.
Dany
Old June 23rd, 2003, 01:26 PM   #448
The academic version is the same as the commercial version.
There is no academic version, only academic pricing.
There are no restrictions on what you can do with it.
When you register, you are entitled to the same support from what I've heard.
Journeyed.com has Vegas 4 with DVD Architec for
269.00. Vegas without DVD architect for 149.
With DVD Architec you get AC3 5.1 encoding capabilities.
check around for the best prices.
Joe Carney is offline
Old June 23rd, 2003, 02:30 PM   #449
which MPEG encoder in Vegas
Hi,
Which MPEG encoder is in Vegas 4.0 ? Did Sonic Foundry make their own?
Vince Denali is offline
Old June 23rd, 2003, 03:01 PM   #450
Vegas 3 and 4 use the Main Concept mpeg encoder.
Brian M. Dickman is offline
