Vegas Video discussions from 2003 - Page 22 at DVinfo.net
Old May 25th, 2003, 10:55 AM   #316
Hi Don,
Thanks for your response.
I managed to suss out the 'add point' functionality of Vegas and it is very, very good.
I still find however, that some of the tracks are a little louder than others after I have finalised my session/project and played it back on my DVD player.
I guess a good set of earphones would help compliment me during the post production.
The master mixer is something I will perhaps tackle in the not too distant future.
Many thanks and regards,
Neil
Neil McLean is offline
Old May 25th, 2003, 11:01 AM   #317
Works Great!!
Vince Skinner is offline
Old May 26th, 2003, 01:43 AM   #318
My guess is that Smart resample lets Vegas decide whether resample is needed or not. Force resample leaves the decision to you. I can't imagine that there is any difference in the resample itself.
Tor Salomonsen is offline
Old May 26th, 2003, 02:01 AM   #319
Slash Rules!
So turning off the resample wouldn't solve my problem? Hell, I don't even know what a resample is. I'm sure it somehow involves sampling again.
Josh Bass is offline
Old May 26th, 2003, 02:22 AM   #320
Turning resample off will make the render go faster. Keeping it "smart" will make Vegas decide - but Vegas may not alway make the right decision as far as flicker is concerned.
Changing the field order may change things, too. What versin of Vegas are you using? There was a bug once that set the field order incorrectly under certain circumstances - can't remember which. If you have V4, make sure you get the 4.0c version. Just install it on top.
You could find a lot of threads on flicker at the Vegas Forum
http://www.sonicfoundry.com/forums/S...=185550&Page=0
Old May 27th, 2003, 10:19 AM   #321
Saving frame x frame in Vegas
Hi all,
I was reading the tutorial on light sabers that was linked from this forum sometime back. I just wanted to see if I could make a couple second clip of my 7 year old son swinging a light saber. The info in the tutorial was for premier and photoshop. I am using Vegas and paint shop pro. They said to save as filmstrip, then bring all frames into photoshop and edit them. I can't see any way to do this in Vegas, so I saved each frame one at a time, edited them, then inserted them as stills back into Vegas. It seemed to work OK, but very time consuming. I can see where retouching the video frame by frame can come in handy for other projects and could make for some wonderful special effects.
Can anyone tell me an eaiser way to accomplish this is Vegas?
Adam VanScoyoc is offline
Old May 27th, 2003, 12:43 PM   #322
High School Student
Vegas -- 24P with 2-3 pulldown, or 2-3-3-2 pulldown? Whats the difference?
Hey, I was hoping someone could explain to me the difference between exporting 24p with 2-3 pulldown, and exporting 24p with 2-3-3-2 pulldown, in Vegas 4.0c...thanks.
Alex Knappenberger is offline
Old May 27th, 2003, 01:50 PM   #323
Sponsor: JET DV
There is a script available that will save any timeline as a series of stills. Look on the Sonic Foundry download page and download the Sample Scripts. MANY scripts are availble that do amazing tasks. One such example is Excalibur at www.VegasTrainingAndTools.com.
Edward Troxel is offline
Old May 27th, 2003, 02:09 PM   #325
High School Student
Thanks, that clears it up.
I don't have a DVX100, but I can still export stuff in 24p 2-3 pulldown mode, in Vegas, and print it to tape back to my camera, with no problems...
Old May 29th, 2003, 10:04 AM   #326
Thanks Edward- I appreciate the quick response. I will check out the available scripts!
Old May 30th, 2003, 01:53 AM   #327
Slash Rules!
Faking a backlit window in Vegas 4
Okay, bear with me. I have a shot of two people on a couch. Behind them is a window, with the shade down and the blinds completely closed. The scene was actually shot late at night, but in the shots from the other direction, we attempted to simluate afternoon sunlight (probably not well, but anyway). The shots from this direction, though, don't look right because the window looks like there's darkness behind it, not light. Even with the blinds down, there should be somewhat of a glow to the window because of how the camera would see it.
I've attempted to fake this with Vegas 4 using the bump map effect set to to omnidirectional, and it looks okay. I was wondering if anyone has any suggestions on how to make it look more real, with the software I have available to me, namely Vegas 4. I can email pics if someone wants an example, but I don't have a site or anything to refer you to. Sorry.
Should we have had our key light outside the window, shining in, the whole time? Why yes, that probably would have worked nicely.
Old May 30th, 2003, 02:53 AM   #328
Do you mean there are little lines of darkness that would otherwise have been light?
If you can identify that colour you may simply change it in colour corrector 1 and/or 2. BillyBoy has a tutorial at http://www.wideopenwest.com/~wvg/tutorial-menu.htm
The Light Rays FX will give you all the glow you want but will not lighten the dark.
Next try: Did you use a tripod? You could export a still and draw the light you need on it. You could then use Light Rays to diffuse it.
(You said you only had Vegas 4 available, but something like PaintShop Pro can be had for a 30 days(?) free trial period.)
Old May 30th, 2003, 09:53 PM   #329
Also, please check out the 24p whitepaper here.
Dennis Adams is offline
Old May 31st, 2003, 10:29 PM   #330
Sparkling/reflective Text- Vegas Users
Hello Guys/Gals,
I am currently working on a wedding project on Vegas 4. At the beginning of the video, I have "Our Wedding Story" as a title. I was wondering how do you make the text appear as if it is sparkling or as if the text has a reflective surface and light sweeps across it? I hope you get the idea.
All relevant tips will be helpful. Thank you.
Jack-of-all-trades trying to master one (Videography)
www.sdfvideo.com
Albert Rodgers is offline
