Vegas Video discussions from 2003 - Page 2 at DVinfo.net
Old January 29th, 2003, 05:55 PM   #16
Vegas 4 and DVD Architect question
Does anyone know what specific features you will be able to get with DVD Architect that you won't get with Vegas 4 (other than the ability to burn DVDs)?
Stephen Sobel is offline
Old January 29th, 2003, 08:07 PM   #17
Rextilleon
Steve--its not burning DVDs--its an authoring program, entirely different then Vegas (an NLE) You author your DVD's---create chapters etc with ARchitect---dont confuse the two.
David Mintzer is offline
Old January 29th, 2003, 08:36 PM   #18
Problem with VV3 - making mpeg2 for DVD will never happen at this rate.
Okay. I have had this problem for days now, I asked on sonicfo. forums with no help. Maybe you guys can help...
When I try to render as mpeg2 (because I will need to burn to dvd soon) it renders for about 2-3 minutes and then I get an error (error unknown)... this is a problem that others on the sonicfo. forums have yet nobody knows how to fix it. I am running out of time and need to get this thing turned into a mpeg2. dvd quality...
Can you guys either:
A. Tell me what is wrong with vegas.
B. Tell me what I should do as far as programs other than vegas that can make good mpeg2s... some "how to's" would be fantastic if you recommend another program. I have never burned a dvd and could use all the help I can get.
Eric Reynolds is offline
Old January 30th, 2003, 03:13 AM   #19
RED Code Chef
Eric,
Download TMPGEnc from www.tmpgenc.net and output your
final movie from VV to AVI. Then load this up in the encoder
and select the correct DVD template. Hit encode and it should
make you a compliant MPEG-2 file. You can try this out for 20
or 30 days.
Authoring a DVD is a whole different game. I believe Nero
can make a self-playing DVD-Video (just drop the file in), but
I'm not sure. Haven't done authoring myself yet.
Good luck
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old January 30th, 2003, 01:22 PM   #20
Slash Rules!
And TMPGEnc's quality was much better than the MPEG that Vegas could make, in my opinion.
Josh Bass is offline
Old January 31st, 2003, 12:56 AM   #21
reply to Tor
Thanks Tor,
I've had 2 problems that no one on these boards has had with VV 3.0.
I was starting to get a complex......heh
Dan Holly
Anchorage, Alaska
Dan Holly is offline
Old January 31st, 2003, 01:24 AM   #22
Vegas Video 3c is the current release, yet
Dan,
Are you using V V 3.0? If yours is a Vegas problem after all, an upgrade to 3 c might help. That is a free download for anyone with a valid 3.0 ownership. There won't be a 3 d, but 4.0 is just around the corner. That will get rid of your complexes (but not your complexion - due to its powerfur colour correction tools - ha ha).
Tor Salomonsen is offline
Old January 31st, 2003, 02:16 AM   #23
Here's the DVD Architect product info:
http://www.sonicfoundry.com/products/dvda-feat.asp
and here's the forum:
http://www.sonicfoundry.com/forums/ShowTopics.asp?ForumID=22
Old January 31st, 2003, 02:39 AM   #24
How do I improve text appearance in VV3?
I've noticed that when I use moving texts in my projects on Vegas Video there are horizontal kind of pixelated lines in the text. I don't know if I am explaining the way the text looks well, but I would prefer more homogeneous smooth appearing moving texts. I am rendering as mpeg2 and I think my settings are just the default ones. Am I doing something wrong or is that just the way they look? Does anyone use a text generator plug-in to achieve better results?
Dan Measel is offline
Old January 31st, 2003, 04:01 AM   #25
Widescreen AR in Vegas different than in Premiere?
I have downloaded and started to play with the Vegas demo (I have no previous experience from Vegas).
The PAL DV widescreen aspect ratio in Vegas is stated as 1.4568. In Premiere the aspect ratio is stated as 1.422 and in EasyChanger as 0.7031 (which is the the same as the inverted value ratio stated in Premiere).
Is there anyone that can shed some light on this issue? As I understand either Vegas or Premiere have/states the wrong AR. I have captured Widescreen DV (from a Sony PDX10P which is stated to record "true" widescreen without being a native 16:9 CCD) and edited in Premiere and in Vegas. Since I've only encoded a short clip (about 1 minute) and I can't view the clips side by side it's hard to tell which gives the most accurate result. However, in Vegas as well as in Premiere it seems as part of the picture is "over the top and under the bottom" (Canopus watermark partly hidden). Could this latter be due to overscan and is it something that I have to live with or could it be that I use the wrong template? In Vegas I have tried output to PAL DV Widescreen (no watermark which might be due to "none watermarked" codec) and Canopus and MainConcept (resulted in watermark).
Any input is highly appreciated.
Hans
Hans van Turnhout is offline
Old January 31st, 2003, 08:01 AM   #26
RED Code Chef
I suspect Premiere is correct since they have the product longer
and also because it is the same value of that other product
(inverted).... but ofcourse I might be wrong
Old January 31st, 2003, 07:18 PM   #27
Hawaiian Shirt Mogul
1.45 or 1.42 ??
for normal ntsc some use .9 others .9091
you can make it whatever you like in V .. so if you want to use the premiere 1.42 ... in V window FILE / Properties ... now in the pixel aspect choose PAL widescreen THEN change the 1.45xx to 1.42 ... this will change the preview window so a clip with aspect of 1.42 will fill it ( no bars on sides)
to make sure your clip has the same pixel aspect ( in V only) so you don't have black bars on sides go to media pool - right click on clip - PROPERTIES .. again change the pixel aspect to pal widescreen then change the 1.45 to 1.42
NOTE that many of these hand size camera's do NOT fill the whole frame from side to side ... so you might not be able to get rid of the black on each side
Don Donatello is offline
Old February 1st, 2003, 07:11 AM   #28
Thanks for the input.
I have done some additional reading and I think that I'm beginning to understand. It seems as Vegas and Premiere uses different basis for the calculation. Vegas seems to use the a method including also the fraction of non-square pixels (702 + 54/59 non square 59/54 pixels per line) that fits in 768 square pixels per line whilst Premiere excludes the fraction. Although the figures differ the visable result might be the same?
Include links to what I have read in case anyone is interested.
http://geocities.com/wunder01au/widescreen.html
and
http://www.mir.com/DMG/aspect.html
Old February 1st, 2003, 09:08 AM   #29
Images: 10
the easiest way to test the image is to record a perfect circle. When viewing the circle after rendering in the NLE, incorrect AR will result in the circle being distorted into an oval, sufficiently to be measured. Be aware than many, many video players, including Micro$oft Media Player, DO NOT convert aspect ratios correctly, nor do monitor screens that have been incorrectly set up.
This is a very thorny issue because of all the potential sources of distortion. Having gone thru this in detail, in the past, most problems come from the player or screen adjustments.
Bill Ravens is offline
Old February 2nd, 2003, 12:37 PM   #30
Stephen, in addition to authorng DVDs you also have the option to turn 5.1 audio into AC3 format. As far as I know, there will not be a standalone AC3 plug-in for Vegas (like there is for Acid). it requires the DVD architect program.
Joe Carney is offline
