Vegas Video discussions from 2003 - Page 111 at DVinfo.net
Old December 4th, 2003, 05:43 PM   #1651
Could you please post the script here, or give us a link.
I find it crazy that a .wmv file won't work in a MS product, and it requires a .mov file. Not saying that you are wrong, I just find it strange.
I'm on FP 2003 at home and I'm not seeing this issue, but I'm at work where we have FP 2000.
Dan Holly
Anchorage, Alaska
Dan Holly is offline
Old December 4th, 2003, 05:51 PM   #1652
Slash Rules!
Thanks. I never intended to slow it down, it was just how it turned out.
Josh Bass is offline
Old December 4th, 2003, 09:30 PM   #1653
I need help with Flix Pro in Vegas
I downloaded the Flix Pro demo to convert video into vector animation. Pretty handy tool. Unfortunately, the file is saved as a SWF file and I need a file I can import into vegas. Anyone have any idea how to do this?
Dan Measel is offline
Old December 4th, 2003, 09:41 PM   #1654
SWF...isnt that a flash format? I thought Vegas *might* read it- did you try?
Glen Elliott is offline
Old December 4th, 2003, 09:50 PM   #1655
You know I thought it would too, but Vegas didn't recognize it.
If there's no way to use SWF files in Vegas does anyone know of a program available to make avi or mpg files with vector animation?
Old December 4th, 2003, 10:13 PM   #1656
If yoru using flash I think it has enough output formats that you might be able to import to Vegas. I thought it had an AVI option but I could be wrong.
Old December 4th, 2003, 11:00 PM   #1657
Sponsor: JET DV
Vegas won't read flash files. Use some other software to convert it to an AVI file and you'll be fine.
Edward Troxel is offline
Old December 5th, 2003, 02:01 AM   #1658
Sorry Edward that I said to turn resample on :) Guess I need to learn a lot hehe. At leats for me it worked but that is probably because I shoot in normal mode.
Joris Beverloo is offline
Old December 5th, 2003, 02:39 AM   #1659
Slash Rules!
Can someone explain how the undersample rate affects the "ghosting". . .e.g. the higher the number the _____ ?
Old December 5th, 2003, 03:38 AM   #1660
I'm not absolutely sure it does, but I thought it was worth a try. If Edwards assumption was right (about the "extra" frames) I thought undersample would be a way to get rid of them without re-adjusting the speed.
Anyway, here's what the manual says:
"The Undersample rate box allows you to simulate a lower frame rate. For example, an undersample rate of 0.5 plays the event at half its original frame rate. Each frame plays twice as long as in the original media file, creating a strobe effect."
On closer inspection though, it seems lowering the undersample rate does the same as disabling resample, only with greater control, because you can fine-tune it.
Tor Salomonsen is offline
Old December 5th, 2003, 08:19 AM   #1661
Sponsor: JET DV
<<<-- Originally posted by Joris Beverloo : Sorry Edward that I said to turn resample on -->>>
Normally you WOULD want it on.
Old December 5th, 2003, 08:31 AM   #1662
Any suggestions on a program to convert the SWF to AVI? I don't even know where to begin looking for something like that.
I checked to see if Flix Pro could render as avi, but from what I can tell it can't.
Old December 5th, 2003, 08:48 AM   #1663
Surprisingly with google I found a couple of programs that say they can convert swf to avi. I'll list them here for anyone who may be interested in the future.
One is winmpg and the other is called magicSwf2Avi
Old December 5th, 2003, 12:16 PM   #1664
http://david.egbert.name/work/newmedia/quicktime/quicktime_in_frontpage/
I'm still having the problem with all movie file formats coming out of vegas. this is driving me nuts! Nobody else has this problem. Maybe i'll just go back to an earlier version. arggggghhh >:-(
Dan Lahav is offline
Old December 5th, 2003, 03:23 PM   #1665
The cheap little Screenblast (vegas's little bro) will imprt flash files from what I have heard. That alone might be woth getting a copy. Hopefully they will add that in Vegas 5.
Screenblast Movie Studio:
Increased format support — Support for import, editing, transcoding, and export of Windows Media® 9 video format, AVI's, Macromedia® Flash™ file format (.SWF), MPEG-1, MPEG-2 and other popular formats.
http://mediasoftware.sonypictures.co...ct.asp?PID=856
Jason Casey
www.jcmediaservices.com
www.kickbacktracks.com
Royalty Free Video Production Loops!
Jason Casey is offline
