Vegas Video discussions from 2003 - Page 102 at DVinfo.net
Old November 15th, 2003, 03:39 AM   #1516
Help! I'm Dropping frames!
Tonight I tried to capture some video with Vegas, exact same set up as I have successfully used for the last 10 months. When I tried it was dropping almost as many frames as capturing. I've checked the obvious (firwire connections) did a reboot and still can't capture. The only thing I have changed since my last capture was added an external maxtor 200GB drive. I unplugged that, but it didn't matter. Also I am still capturing to my internal hard drive so it doesn't seem like the maxtor could be the problem. Any ideas, I am a computer idiot?
I use a 1.8GHz, p4, 1GBRAM with XP.
Dan Measel is offline
Old November 15th, 2003, 11:10 AM   #1517
Peaks? Normalize?
I'm looking at the Vegas 4 demo and reading the manual, but having a hard time understanding the function of the peaks and normalize features/functions.
One problem I've had with the entry level SW (Studio8) I've been using is that on long projects having native sound, then voiceovers and CD tracks added, the overall sound level becomes inconsistent. Can I easily solve this problem in Vegas? The two minute clip limitation in the demo makes it hard to evaluate this function....
RalphM
8mm/S8/16mm film-to-video transfers
"Before they are gone forever..."
Ralph Morris is offline
Old November 15th, 2003, 11:14 AM   #1518
Dan,
Sounds like it's worth checking the fragmentation level on the the hard drive. Also, What happens if you capture to the new Maxtor?
RalphM
Old November 15th, 2003, 12:01 PM   #1519
Vegas Video discussions from 2004
I'm just getting into vegas. I bought it a month and half ago but started into it this week. I think i'm getting a handle on it but wading through that manual sure sucks.
I noticed there were tutorials online but they disappeared after sony took over. I'm afraid of getting into a project only to discover that i've gone in the wrong direction. I'm sure once i get my feet wet i'll be OK.
Bryan Beasleigh is offline
Old November 15th, 2003, 01:32 PM   #1520
Thanks. I am defragmenting now, hopefully that will solve the problem.
Old November 15th, 2003, 05:19 PM   #1521
Can Vegas 4 capture the HD10's MPEG2 video.
In Vegas 4, I have been able to view .m2t video files I downloaded online. I was wondering how to capture the HD10 MPEG2 video into Vegas 4. Is it possible and how would it be done. I would like to capture and view the 1280x720 HD video in Vegas from the HD10.
Doug
Doug Wright is offline
Old November 15th, 2003, 06:19 PM   #1522
After 5 hours of defraging still can't capture. Looking into reformatting my hard drive or buying a new computer now I guess.
Old November 15th, 2003, 08:27 PM   #1523
reversing clip
Hello,
Is there a way in Vegas to reverse a clip. for exampe you have a clip of a car driving in reverse, and you wish to make the car look like it is driving forward..
Mike M.
Mike Moncrief mikemoncrief@gmail.com
www.themikemoncrief.com
Mike Moncrief is offline
Old November 15th, 2003, 08:36 PM   #1524
Sponsor: JET DV
Insert a velocity envelope. Change the "speed" to a negative number. -100% = full speed reverse.
Edward Troxel is offline
Old November 15th, 2003, 08:39 PM   #1525
Sponsor: JET DV
Check the DMA setting. Sounds like it may have gotten turned off some way.
Old November 15th, 2003, 08:41 PM   #1526
Sponsor: JET DV
Take a look at the "Beginner's Corner" articles in the Vegas Tips, Tricks and Scripts Newsletter at http://www.jetdv.com/tts
Old November 15th, 2003, 08:49 PM   #1527
Sponsor: JET DV
Any individual clip may be normalized but that won't guarantee each of them are at the same volume level.
The volume may be fully controlled by using the Volume Envelope, Track volume, and master volumes. If you want, you can also create busses which also have volume controls. So, yes you can make the volume consistent by using a combination of tool.
Old November 15th, 2003, 08:51 PM   #1528
Sponsor: JET DV
Sounds like when you FIRST loaded the file, you cancelled the peak file build. You found the solution - just rebuild them. Pressing F5 will also do this.
Old November 15th, 2003, 10:45 PM   #1529
Sponsor: JET DV
Videoguys was kind enough to host the newsletter for me. I was getting so many hits that I nearly exceeded my bandwidth and had to find an alternative. So I appreciated Videoguys being willing to host the PDF files.
Old November 16th, 2003, 01:04 AM   #1530
Edward, thank you for your input. But I don't know what a DMA setting is. Is that in Vegas or XP?
