Batch Render? at DVinfo.net
Old December 14th, 2005, 01:40 PM   #1
Batch Render?
I have a Vegas 6 project that is separated into two .veg files, each with a little over 4 hours of video. I need to render the beast to 16 individual DVD-MPG2 files (8 segments in each .veg) I would rather not have to be at the PC to start a new render of each section every time. Is there a way to batch render, even if I created 1 veg file for each of the 16 segments, so I could just come back tomorrow and have all 16 files rendered? or, would it cause any harm if I opened 16 copies of vegas and rendered all 16 simultaneously, realizing all renders would be significantly slowed, but still, I could leave and come back to 16 rendered files.
Any ideas on the best way to render 16 files?
Chris Thomas is offline   Reply With Quote
Old December 14th, 2005, 01:55 PM   #2
Identify each segment as a Region (make selection/hit the R key) and then use Tools>Scripting>Batch render, and assign it to render regions.
That's the easiest method I'm aware of. Much more effective than opening 16 copies of the veg.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old December 14th, 2005, 02:10 PM   #3
Thanks, I just set up the regions, and will give it a whirl. With this method, how do I set the specific bit rate and other settings for the MPG2?
Old December 14th, 2005, 02:14 PM   #4
Scratch that, I figured it out... By making my adjustments and saving a new template with the appropriate settings.
Old December 14th, 2005, 02:16 PM   #5
You found it, I guess...modify a template.
You *might* find this small tutorial of use;
http://www.vasst.com/resource.aspx?i...f-3f7950d7c353
Old December 14th, 2005, 04:22 PM   #6
Would this work for separate VEG files?
Say you have 5 different video projects of 12 minutes each and you want to render them all by pushing a button and then leaving. Is there a way to create a "job" that would render all 5 of the VEG projects? Can this be done with batch render or would I need some other tool? ph
Phil Hamilton
hamiltonp@sbcglobal.net
Dallas, Texas
" I'm shocked, shocked to find that gambling is going on in here! ..."
Phil Hamilton is offline   Reply With Quote
Old December 14th, 2005, 04:24 PM   #7
That is precisely what a batch render does. The tutorial referenced above will show you exactly how to do that, but it's mostly a matter of using checkboxes to mark what types of files you want.
Old December 14th, 2005, 08:51 PM   #8
Say you have 5 different video projects of 12 minutes each ...
You can set up a render cue using the Network Render utility (even if it's on the same computer doing a non-distributed render).
Gary
Gary Kleiner is offline   Reply With Quote
Old December 15th, 2005, 08:32 AM   #9
Gary
I thought the network render would not work on an individual computer but now I know and I will certainly try creating a queue with that. tks
Phil Hamilton
Dallas, Texas
Old December 15th, 2005, 10:07 AM   #10
Sponsor: JET DV
If you haven't seen the Veggie Toolkit, it is a very flexible batch rendering program:
http://www.peachrock.com/software/veggie-toolkit.html
Edward Troxel is offline   Reply
