Beast laptop to edit with Vegas and eventually AE
Hola,
could you help me in the upgrade choice for a beast laptop for Vegas? I'm planning to work even with After Effects Yhank you so much p.s: i was wondering in a DELL.... |
Re: Beast laptop to edit with Vegas and eventually AE
The best laptop would be the most expensive one you can afford.
A little knowledge goes a long way but not long enough. |
Don thank you for your suggestion but...under 2000$ what would you suggest?
The new Apple m1 looks interesting.
#5 |
#6 |
Thanks Pete!
#7 |
A typical price range for video editing laptop is around $1,600-2,500
The following are a few specs you should look for: cpu i7 16gb ram 1tb nvme drive discrete video card (this is the biggest price differentiator) 15-17" screen. The problem with laptops they have difficulty dissipating heat, leading to loud fans or throttling. Sometimes going with a higher end cpu doesn't result in better performance because of the additional heat and then ensuing throttling. |
#8 |
I've also been investigating the possibility of moving over to a "beast" laptop. A top of the range laptop is very expensive - obviously - however its cheaper than a high-end desktop + a mid-range laptop (n.b. a laptop that might disappoint if its "only" 1080p rather than 4k and with a slowish GPU).
I am used to using two 1080p screens on my desktop. I would want to retire the desktop and move over to a beast laptop that can do 4k on its built-in screen plus run a 2nd 4k screen of e.g. 27" when I want to work at my desk. But I also want to do everything just on a laptop when I'm elsewhere. My current Dell XPS is 15.6" and I find that rather to small to work on especially with the likes of Vegas Pro and Capture One Pro. Therefore I would want a 17" laptop screen. 16gb saves some money but 32gb is probably a safer long-term bet - though you can use Vegas proxy up to a point anyway. Likewise a GPU something like the Nvidia RTX 2060 6GB makes sense. Likewise an i9 for long-term. I prefer Dell over suppliers as my kit has been reliable long-term and their availability to solve any problems is decent. The specific Dell laptop I've been looking at is their new XPS 17: https://www.dell.com/en-uk/work/shop...configurations Its around £3k at present so substantially over the OP's desired limit but ..... Its also worth keeping an eye on the likes of Dell Alienware in their outlet shop. Pete EDIT: There are some very knowledgeable members on the dedicated Magix Vegas forum, so do check that out as well: https://www.vegascreativesoftware.in...gas-pro-forum/ Last edited by Peter Riding; January 6th, 2021 at 07:58 AM. |
#9 |
I've had good luck with Sager. Their web-site is www.sagernotebook.com. I've bought four computers from them, starting in 2008 and my most recent one in 2018. I have a i9 series CPU with 64GB RAM, four 2TB SSDs in two RAID arrays. So, a 4TB RAID C drive and 4TB RAID D drive. It works pretty good for my 4K editing.
It was about $6,000. A couple of reasons I keep going back to Sager: They offer lots of customization on their web-site. Easy to configure with RAID, for example. They don't put any bloatware on their machines. I've had the extended warranty and had to get it repaired and that was a good experience. You start out by selecting screen size. Currently showing eleven models in 17" size. You can get them for under $2,000, but if you want lots of on-board, fast RAM and lots of fast storage memory, it will run the price up. Mark BTW: I mostly edit with Vegas (13 and 15 pro) but also use photoshop. I have Premiere but rarely need to use it nowadays. Last edited by Mark Watson; January 9th, 2021 at 04:15 PM. Reason: Added info. |
