Should I use 4K vs HD? I need advice. - Page 2 at DVinfo.net
Old August 18th, 2018, 07:04 PM   #16
re: Should I use 4K vs HD? I need advice.
Originally Posted by Seth Bloombaum View Post
* 4k delivery is needed in some markets.
* 120fps slowmotion is needed in some markets.
* 4k workflow *can* slow you down, and/or, cause the need for a new computer. You really need a recent generation i7 processor or better. But, short of that, if in workflow trouble, transcoding to HD or to a 4k editing codec is always possible.
If I were shooting surfing and any “extreme” sports, I would DEFINITELY want 120fps slowmo. Totally worth $350 on its own. That’s a 4x slo, with no resolution loss, an easy edit, and no tricky tweening software. IMO that’s more important than 4k right now.
Bear in mind that the 4k cam will likely shoot in HD if that’s needed. And, you’ll really like seeing your from-the-water shots at 4x slowmo!
There is a lot of wisdom in your comments, thank you.
Jeff Wisener is offline   Reply
