makng ang audio track sound like it has come to a stop at DVinfo.net
Old April 20th, 2017, 03:48 AM   #1
I want to illustrate the idea of the heat death of the universe. Visually this is simple...the screen goes black.
However I want to illustrate it audibly by the sound of me saying "The heat death of the universe", sounding like it is a record that comes to a halt. I've tried stretching the audio so it slows down but that is not the right sound...the sound has got to get deeper.
Anyone have any ideas on how this could be accomplished?
Renton
Renton Maclachlan is offline   Reply With Quote
Old April 20th, 2017, 05:52 AM   #2
Re: makng ang audio track sound like it has come to a stop
i'd simply cut 'universe' to 'uni...' then a 1hz tone as in blank transmission.
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old April 20th, 2017, 02:32 PM   #3
Uuummmm...I've never been this way before.
'A 1 hz tone as in blank transmission'. Not sure I know what that means.
The sentence needs to be decipherable but wind down in speed and tone... like a turning record on a turn table coming to a halt due to the weight of the needle or the power to the turn table being turned off.
Renton
Old April 20th, 2017, 05:52 PM   #4
i know what you're trying to achieve, but the only way i can see to do it is with 'old' technology ;-(
could try time stretch in vegas?
Old April 20th, 2017, 09:10 PM   #5
I'm pretty sure Audacity can do this for you
Select the snippet of Audio you want and the use Sliding Time Scale / Pitch Shift.
Vince Pachiano is offline   Reply With Quote
Old April 20th, 2017, 09:49 PM   #6
I have Goldwave audio editor which can do most things apparently, so I'll try that in there.
Thanks.
Old April 21st, 2017, 01:41 AM   #7
Old Boot
Renton
I just did it in Sound Forge with Pitch Bend. Works nice - UPLOAD issue with WAV, now in ZIP:
http://www.dvinfo.net/forum/attachme...1&d=1492760374
Is this the type of thingy?
G
Old April 21st, 2017, 03:11 AM   #8
Re: making an audio track sound like it has come to a stop
Well...I've got more or less what I wanted via Goldwave. It doesn't have a 'sliding time scale' nor anything like keyframes that I can see, but it does have pitch and time, both affecting the whole file or selections.
Thus with the phrase 'the heat death of the universe', I was able attribute to each word a progressively lower pitch which basically gave me what I was after...
Renton
Old April 21st, 2017, 03:12 AM   #9
Old Boot
Neat. Can we hear it?
Old April 22nd, 2017, 03:36 PM   #10
Attached find file. It is not exactly what I was after but it will serve my purpose...
Renton
