#16 | |
Re: How do I render 4K video in Vegas Pro 13?
Hi
2 pass is probably not necessary, more important at lower bitrate settings and where you want a guaranteed file size, but will essentially double the time it takes as it does two encodes. Laptops often throttle down as they get hot which just makes things slower. Mark has recommended SSDs etc, but that really only makes a difference if the rest of your system is able to achieve near real-time speeds, as it stands, the storage system isn't the bottle neck at the moment. There are other encoders you can use, and newer Intel CPUs basically have a separate chip in the CPU that is designed just for encoding video, and can do this extremely fast using little power (Google Intel QuickSync). Note to use things like QuickSync you need an encoder that knows it is there and will use it, I don't think such an encoder is in Vegas 13. Edit, tell a lie, if you use the Sony AVC encoder in Vegas QuickSync is available if supported by your CPU, not sure it does 4K, will have a play around. Regards Phil |
