#31 |
Re: PC, these specs, graphics card confusion
I was also skeptical about win 10 and tried to hold on to 7 as long as I could, you know, why change if everything works just fine but not so long ago I did change to 10 when it was still free to upgrade and have not regretted it, it's like a polished 7 version, the changes just take getting used to but there is nothing drastically different. Most important is to check if your NLE supports win 10 and if so you are good to go.
#32 |
Thanks, it's good to know that 10 seems to be working well. My NLE is vegas pro 14.
Thanks, Paul.
Round 2 GH5,FZ2000 |
#33 |
Quick update
CSW I7 BASE UNIT Intel Core I7-6700 CPU ASROCK Motherboard 4x DIMM Slots (supports maximum of 64GB RAM) 256GB Kingston SSD Drive 3TB 3.5 Toshiba HDD 32GB DDR4 Kingston Memory 500w Bequiet Power Supply Antec Black Matte Case front USB 3.0 x 2 ports ASUS Radeon DDR5 RX480 8GB Overclocked 2 x HDMI ports DVD/RW Windows 10 Home 64-bit £1270 It's absolutely flying !! Paul.
#34 |
Paul, did you have that PC built for you, or buy it off the shelf? I'm looking for a new PC fairly soon.
#35 |
Hi Matt.
The specs above, i had it made. A comparable pc in currys was £2000 so i saved over £700. Plus i've also actually got a warranty etc with these people, the person who built my pc is in the shop every day so if i did have a problem then it would be sorted very quickly. Give them a call, tell them i sent you. Computerhire South West Ltd - Laptop repairs in Bristol Paul.
#36 |
Thanks Paul.
