Vegas Edit vs Pro - Page 3 at DVinfo.net
Old November 27th, 2016, 10:33 AM   #31
Re: Vegas Edit vs Pro
Thanks, George. I have seen a few of the YouTube tutorials, and found them quite confusing. But at least I have figured out one of those plugins by now and will probably make a tutorial myself. Especially since my new computer is an MSI GT72s 6QE Dominator Pro G laptop with the Nvidia GTX980M video card that allows me to record anything I do with the computer (including sound) straight into an MP4 video using hardware compression.
And I am hoping that eventually I will somehow figure out the rest of the plugins.
Adam Stanislav is offline   Reply With Quote
Old November 27th, 2016, 03:57 PM   #32
See if this holds true. "Help documents for individual BCC effects are accessible directly from each plug-in’s UI." (Click ?) And "The BCC help system is also available on the BorisFX website at ww.borisfx.com/helpdocs."
Jorma Nippala is offline   Reply With Quote
Old November 27th, 2016, 04:36 PM   #33
Thanks, Jorma. Yes, it gives you a help document, mostly for using the plugin with Adobe AE. That is a far cry from a Vegas-plugin-specific PDF file to print out on paper and read comfortably. Vegas itself comes with such a PDF (though that PDF claims there is an add keyframe button at the bottom of effects, which was true before v.14, but the button is missing in v.14, you have to double-click at the place you want to add the keyframe instead).
