PC Hardware Recommendations for Vegas at DVinfo.net
Old August 31st, 2016, 11:11 AM   #1
Apologies in advance if I have posted this in the wrong place.
I've just purchased Vegas through the special offer made available by Magix.
I assume that my five-year-old PC will not be up to the task so I was wondering if someone could recommend some systems for consideration.
I'll probably go with Dell or something similar, I'm even thinking of a laptop solution if that sounds reasonable.
Any comments or advice?
John Gilmore is offline   Reply With Quote
Old August 31st, 2016, 05:01 PM   #2
Re: PC Hardware Recommendations for Vegas
what's your old pc?
what formats are you editing?
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old September 1st, 2016, 06:12 AM   #3
Not quite sure what it is except that it's very old.
I'll be editing 4K (XAVC 25p 100mbit).
Old September 1st, 2016, 07:16 AM   #4
A powerful 5 year old computer will handle 4k better than a bog standard brand new machine. I suspect your machine may not be that powerful if you're unware of the spec.
These are the System Requirements on the Vegas 13 site. Since you're editing 4k I wouldn't go for less. A USB 3 port would also make sense
Microsoft® Windows 7, Windows 8, Windows 8.1, or Windows 10 (64-bit)
2 GHz processor (multicore or multiprocessor CPU recommended for HD or stereoscopic 3D; 8 cores recommended for 4K)
1 GB drive space for program installation
SSD or high-speed multi-disk RAID for 4K media
4 GB RAM (8 GB recommended; 16 GB recommended for 4K)
OHCI-compatible IEEE-1394DV card (for DV and HDV capture and print-to-tape)
USB 2.0 connection (for importing from AVCHD, XDCAM EX, NXCAM, or DVD camcorders)
Windows-compatible sound card
DVD-ROM drive (for installation from a DVD only)
Supported CD-recordable drive (for CD burning only)
Supported DVD-recordable drive (for DVD burning only)
Supported BD-R/-RE drive (for Blu-ray Disc burning only)
GPU-accelerated video processing and rendering requires an OpenCL™-supported NVIDIA®, AMD/ATI™, or Intel® GPU with 512MB memory; 1 GB for 4K.
Microsoft .NET Framework 4.0
Old September 1st, 2016, 11:06 AM   #5
Hi John,
A 6-core CPU should preview 4K source at full speed for 25p. 4K at 50p maybe not, I've never tested it. 8-core would obviously be better. If you have 4K source media you could simply test it on your current PC. Most likely you will want to let Vegas Pro 13 build proxies files, which of course run much easier than 4K source. If you don't want to install your purchase copy on your old box, you could download the trail version, install and test it.
Best Regards.....George
George Dean is offline   Reply With Quote
Old September 8th, 2016, 11:43 PM   #6
Also for Vegas, having a Radeon-based video card with OpenCL is a must. Made a huge difference in rendering speeds for most of the projects I work on.
Jeremiah Rickert is offline   Reply With Quote
Old September 16th, 2016, 05:24 PM   #7
I build a new machine every three years. Make sure you get a solid state drive for editing imo, I'm fine with my two external g-drives, but a solid state drive will be better for your OS.
I spent about 2k on this machine after all was said and done, but that was just the box and external drives. Although, Sony Vegas is now owned by Magix, so it might be worth an email to them to find out what they think.
Steven Davis is offline   Reply
