Fit 3 hours in a single DVD with DVD architect at DVinfo.net
Old June 27th, 2016, 01:24 AM   #1
Hallo guys,
Could you help me with the settings of Vegas 10 to fit 3 hours of DVD in a single 4.7 DVD?
Thank you
Old June 27th, 2016, 04:48 AM   #2
Re: Fit 3 hours in a single DVD with DVD architect
Interesting that I got the exact same question on another forum when I logged on today :)
Here's the Vegas render settings I get with the bitrate calculator I use. Be advised that if you have a lot of fast motion it may not look that good due to the low bitrate. Render a short segment in Vegas, watch it and see what you think before rendering the entire project.
Audio: AC-3 default of 192
Video: 2-pass VBR render. MAX - 5,976,000, AVG - 2,984,000, MIN - 2,240,000
Old June 27th, 2016, 05:04 AM   #3
For very long DVD it is better to use a smaller frame size (352x576).
Juris Lielpeteris is offline   Reply With Quote
Old June 27th, 2016, 05:52 AM   #4
If you can manage it, a DLdvd is more likely to provide the space you need for 3 hours
Or do 2 x single 4.7gb dvd as in Part A and Part B
Bruce Dempsey is offline   Reply With Quote
Old June 27th, 2016, 06:12 AM   #5
DVDArchitiect does not have the best encoding. If you have TMPGenc it will do a better job with the similar settings to what Mike suggested. Then bring the file into DVDArchitect.
Ron Evans
Old June 27th, 2016, 08:25 AM   #6
I've done a few different DVD projects that were 3 hours long, and both were talking head/training-type videos and the quality looked just fine using a 4.7GB DVD. Would not try this on a video with a lot of motion though!
Jeff Pulera
Digital Vision
Old June 29th, 2016, 12:06 AM   #7
Thank u all!!!
What about if i decide to burn 2 dvds from 4,7 gb; in that case what would you suggest me?
Old June 29th, 2016, 03:15 AM   #8
Still do a 2-pass VBR but use these render settings.
MIN: 3,696,000
AVG: 6,168,000
MAX: 7,712,000
Old June 29th, 2016, 06:30 AM   #9
i have an program that I found years ago called Bitrate calculator. Using 192 dolby digital, it came out to
min 2400
avr 3208
max 6416
David Stoneburner is offline   Reply With Quote
Old June 29th, 2016, 07:54 AM   #10
David, if you're referring to Mark's Bitrate Calculator, that's the same one that I use.
The reason for my lower numbers is that I bump my safety margin up to 5% from the default 1% as I like a bit of extra room, just to be on the safe side :-)
The other change I make is to click the 1 Kilobit = 1,000 bits option (found after clicking "Settings".
If anyone wants it, I keep a copy on my Dropbox account at
https://dl.dropboxusercontent.com/u/...bitcalc110.zip
Old June 29th, 2016, 08:09 AM   #11
I usually do that as well but just went with the default for his purposes.
Old June 30th, 2016, 01:50 AM   #12
It seems as for maximum average and minimum vbr i have just 3 options:
192000
4200000
9800000
What am i missing?
Old June 30th, 2016, 03:03 AM   #13
putting in your own figures ;-)
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old June 30th, 2016, 07:50 AM   #14
Leslie is right. Type in your own numbers and save it as a preset for future use. I've got several presets that I use all the time.
Old June 30th, 2016, 08:19 AM   #15
Wouldn't a dual layer DVD mean he could avoid the low bitrate issue?
Robert Benda is offline   Reply
